Running No Crank Pulley?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Turbrospeed, Mar 31, 2023.
  1. Turbrospeed
    Turbrospeed Light Load Member
    144
    111
    Apr 23, 2020
    Texas
    Hey guys hope you are safe out there....I wanted to ask if its ok to run my 60 series detroit engine with no crank pulley?
    I recently installed electric fans so basically no need for any belts.
    I have a new vibratech damper and pittsburg power balancer installed recently.
    I know its a silly thing to ask but i want your thoughts since i have seen a aluminum crank pulley for 60 series.. so if you can run a lighter crank pulley then why then no pulley at all??
    I do notice that the 60 series crank pulley has dimples in the back part...does this mean its balanced to the engine?
    Thanks for any replys
    Rideandrepair Thanks this.
  3. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    How are you driving the Alternator & Air con Compressor..??
    Bean Jr. and Rideandrepair Thank this.
  4. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    They run off the water pump with 2 belts... a separete pulley system. Its a 97 engine.
    Bean Jr., Rideandrepair and haycarter Thank this.
  5. Big Road Skateboard
    7,115
    40,387
    May 2, 2021
    You need the balancer. What area do you run? I could see electric fans working in some situations, but not most.
    Did you do any research on the volume of air moved by a traditional fan clutch setup?
  6. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    So the crank pulley is a balancer?
    I run mostly mid west to east and back .... i know its not summer yet and well the 4 fans i have on right now put out 10k in cfm total ... Most of the time i dont use them since the engine temp stays under 180f .... So far ive run the engine up about 190 and with just 2 fan temps will lower down to 175f ... this was at idle. I havnt gone up any steep grades yet.
  7. Big Road Skateboard
    7,115
    40,387
    May 2, 2021
    Gotcha. No, don't need the pulley, just the balancer. Sorry, I misread.
    How has your A/C high pressure been affected?
  8. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    Yea i got a vibratech damper and pittsburg power balancers on there right now and with no crank pulley the engine is pulling alot better and seeing a bit more mpgs
    Well usually i turn on the ac on idle then back on when cruising but ive had it on on idle with just the 2 fans up top the ac blows pretty cold ... mind you they are 16inch fans... i posted on here with pics to show.... search for electric fans
  9. Rideandrepair
    17,566
    56,912
    Aug 8, 2015
  10. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    Update guys i ended up putting the crank pulley back on... i wasnt too confident with the nuts i used for spacers.. but ill probably put that aluminum pulley from fitzgerald later on....i weighed the crank pulley at 16lbs and i saw some mpgs increase in just 600 miles without it on.
  11. Rideandrepair
    17,566
    56,912
    Aug 8, 2015
    Running off the assessory drive. Like any series 60. Right?
