Running power through back wall of sleeper
Discussion in 'Ask An Owner Operator' started by Dwight Goertzen, Feb 19, 2025.
  1. Dwight Goertzen
    Dwight Goertzen Bobtail Member
    28
    16
    Jan 2, 2024
    Hello I'm trying to run wiring to a strobe light mounted on the top of my sleeper at the very back. I'm thinking ill run it out the cab underneath and then run it all the way to the back underneath. Then I want to run it inside the back wall of the sleeper up to the roof. I'm wondering if I can drill a hole on the bottom and top right in line with a channel and then fish the wire thru the channel so I don't have to take apart the interior? Is this possible? Or any other suggestions?
  3. SomeCanadian
    SomeCanadian Light Load Member
    166
    481
    Nov 11, 2021
    Without more info and x-ray vision, not likely to work. The few sleeper back walls I’ve looked at have horizontal bracing at least at the flattop roof line. (Yes, in a condo height as well.) some at the belt line half way up.
    Strip the interior and look.
    86scotty Thanks this.
  4. SomeCanadian
    166
    481
    Nov 11, 2021
    Get some wire hider track at the depot and stick it to the outside. ?
    Rideandrepair Thanks this.
  5. Dwight Goertzen
    28
    16
    Jan 2, 2024
    I would rather take the interior apart then put something on the back of the sleeper
  6. 86scotty
    86scotty Road Train Member
    4,728
    12,991
    Aug 27, 2017
    Appalachia
    Don't drill holes anywhere on the back wall or roof of your truck if you can avoid it. Go through the floor and then up the back wall outside. Plenty of ways to do this cleanly.
    What rig? A pic would help.
  7. Vampire
    Vampire Heavy Load Member
    774
    27,776
    May 14, 2011
    Transylvania
    Excellent advice. :thumbright: Hit the nail on the head.
  8. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    They sell grommets that when you drill the hole you drill the right size for the grommet.
    I can't remember where I got mine.
    Silicone the grommet and you're good.
  9. Dwight Goertzen
    28
    16
    Jan 2, 2024
    Good idea, that's what I'll pry do! I guess there enough holes on the top of the cab that don't let water in i don't know why I couldn't do 1 more‍♂️
