S60 12.7 injector upgrade
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tomek373, Aug 2, 2022.
  1. Tomek373
    Tomek373 Bobtail Member
    29
    5
    Mar 12, 2021
    Hello guys I currently have 350 hp s60 12.7. It’s a turd and I do mix heavy to light loads Midwest to east coast. I ordered bw airwerks 171702 and I’m doing Pittsburg power 500 hp and 1950 tq tune. The turbo is on back order so it will take few more weeks to get it. My fuel economy recently went down a bit And I notice black smoke when I start rolling or get on the highway from Ramps but once I’m at steady Rpm’s it goes away. I’m guessing my injectors are going out. I currently have 7099 injectors with 8309 cam. Can I install 5915 injectors now and then when my turbo comes in get that installed and get the tune or would I need the tune for the 5915 injectors right away ? I don’t want to replace with same injectors since I know I’ll be going up with power and I also don’t want to tune it twice ‍. I also have full tilt ceramic coated exhaust manifold installed too already since old one was leaking
  3. Big Road Skateboard
    7,114
    40,375
    May 2, 2021
    Injectors aren't your issue. Have you already done the tune? Also not a fan of the S400 with your setup. What turbo is on it now?
    RubyEagle Thanks this.
  4. Tomek373
    29
    5
    Mar 12, 2021
    What could be my issue ? And no I have no tune so far I’m all stock oem except for exhaust manifold which is full tilt. I have mk60 model with only 350 hp and turbo is some kind of wastegsted garret
  5. Big Road Skateboard
    7,114
    40,375
    May 2, 2021
    Don't change anything till you get it tuned. PP is gonna give it all it will get, which may be too much. If you're not careful, you may be without a truck soon. Do you have a pyrometer?
  6. Tomek373
    29
    5
    Mar 12, 2021
    Why is that ? From my research through out the forum I found that 5195 injectors..BW 171702 and exhaust manifold with proper tune and it’s good. I’m only going to 500 hp nothing crazy and yea I have pyrometer and mechanical boost gauge (coming in shortly )
  7. Big Road Skateboard
    7,114
    40,375
    May 2, 2021
    Your black smoke is coming from a boost leak most likely. Have you checked your CAC and hoses? I tried two different S400's on my PP tuned 325 60 Series, stock injectors and cam. The S400 SHOULD have performed better, but it didn't happen in real life. Lower boost PSI, slower pickup by a lot, higher EGT's.
    I told PP to tune mine to 425 HP. Me having never driven before was a bit ingnorant. Super high EGT's, hard to keep coolant temps down.
    Looking back, i should have done the radiator and CAC first, then exhaust manifold and turbo. I never changed from factory injectors or cam.
    And my 425 tune? IDK, that truck was super fun to drive. Literally nothing could hang with it. A buddy drove it out west for me 10 times or so, and he had quite a few years experience, and commented often it ran better than any truck he ever drove.
    He has now bought a 379 with a C16 600 horse. Told me the other day that C16 couldn't hang with my old truck.
    Point being, don't trust PP #'s.
    RubyEagle and Tomek373 Thank this.
  8. Tomek373
    29
    5
    Mar 12, 2021
    Hmm okay gotcha now. Maybe I can contact someone from diesel freak in Michigan and see what they can do and what info they can give me. And no I haven’t checked my car or hoses it doesn’t seem like I’m losing any power and the black smoke only pops up for little bit during acceleration then it’s good. Maybe it’s always been smoking a little I just never noticed idk at this point. I’m waiting for my boost gauge to come in to see what I’m boosting and also waiting for oil test kit from blackstone to see if I have fuel dilution in my oil. Last time
    I did sample it was good so will see this time
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Don't waste your money with them. Leon Smith doesn't seem to disappoint.
  10. Tomek373
    29
    5
    Mar 12, 2021
    How Do I contact him? I saw him mentioned in bunch of posts before
  11. Tomek373
    29
    5
    Mar 12, 2021
