SamSara drive clock
Discussion in 'Experienced Truckers' Advice' started by Rob208, May 24, 2023.
  1. Rob208
    Rob208 Bobtail Member
    The drive clock shows I have drive time. My notifications indicate I'm about to run out. Anyone know why this happened? I was in split sleeper. No violation after using the time on the clock. Logged in after reset to clock violations.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,030
    2,189
    Dec 15, 2021
    Check your log,maybe you can edit it if there's an error in your off time.
  4. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    If you leave the app when driving and have a notification pop up when NOT on the app, on the Home Screen it will think it’s going past the 8 hour drive time UNTIL you re open the app and it synchronizes.
    It’s a weird tick of the app but it takes about 2-5 seconds for the app to “update” all your times after you open it back up.
    Chinatown Thanks this.
  5. tscottme
    tscottme Road Train Member
    My ELD did something similar when I was using split-sleeper break. It would show a violation on the screen because it could not see ahead of the current moment while you are driving. All it knew is I started driving before I had 10 hour break. It would eventually correct itself, maybe after I finished the second break period. I don't recall.
