Satellite t.v.? Wineguard system anyone?
Discussion in 'Swift' started by truckbuddha, Feb 20, 2016.
  1. truckbuddha
    truckbuddha Medium Load Member
    490
    201
    Nov 26, 2012
    Salt Lake City, UT
    I see at a TA a satellite kit and was wondering if anyone else has this system and what your experience is.
    The antenna and receiver is about $550, another $100 for a window mount. The programming package is a bit outrageous with all the movie channels, $139/month, but still it includes most of them.
    thanx
  3. passingthru69
    I bought my Wineguard system at a RV dealer.. But mines a roof mount.. Love it, would never go back to the old dish setup and having to set it up every time and then take it down in the morning
  4. truckbuddha
    490
    201
    Nov 26, 2012
    Salt Lake City, UT
    What worries me is the Freightliner Condo I have, that with a roof mounted antenna it would put the truck over 13'6", so I am pretty much considering getting a window mount, that would be free when ordering the system for the Wineguard site for $500.
    Have you met anyone with the window mounted antenna, and do they have any issues with that?
    And plus, could this receiver and a t.v both be ran off a small 300 watt inverter?
    thanx,
    don
  5. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    I went with the dish tailgater, around 350 including the receiver. Monthly charge is $60, but I don't have movie channels.
  6. truckbuddha
    490
    201
    Nov 26, 2012
    Salt Lake City, UT
    Do you use a small inverter or a larger one? I hope to be able to use this system with a 300 watt one.
  7. DrFlush
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    A small one, I think its four hundred watts, I can check tomorrow. It runs my tv, satellite and Aventi cooler, plus a small crock pot type unit on occasion
    truckbuddha Thanks this.
  8. Moosetek13
    Moosetek13 Road Train Member
    15,006
    19,072
    Nov 1, 2010
    Burnsville, MN
    If you are using an inverter that plugs in to the 12V socket you can expect around 150W maximum, so base it on that figure.
    The 300W output is dependent on connecting it directly to the battery.
    If you are using an inverter that connects directly to the battery there is no reason to get such a small one.
    But even if you can't run both using a plug-in inverter, you could always get two inverters and plug them in to different circuits. One in a dash plug and the other in the bunk area.
    In some trucks every plug is on its own circuit, while in others some of them share. Be sure how your truck is set up before you try to use two inverters.
  9. DrFlush
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    I went with the smaller unit because its twice as much as I need and I didn't want to spend the extra money for bigger wire to install a bigger unit.
  10. MysticHZ
    MysticHZ Road Train Member
    5,910
    5,738
    May 28, 2010
    If you're going to spend the money for a SatTV, why not go all out and spring for a 2K watt inverter?
  11. Moosetek13
    15,006
    19,072
    Nov 1, 2010
    Burnsville, MN
    Bigger is better with an inverter.
    You don't want to run it at near max output. It will burn out much sooner.
    It's the same with computer power supplies.
    With a 25% load it may last forever, but may fail in a few months under a 75% load.
    Cranky Yankee Thanks this.
