Scale
Discussion in 'Questions From New Drivers' started by Mcg0958, Aug 30, 2018.
  1. Numb
    Numb Crusty Curmudgeon
    4,333
    10,298
    Jan 30, 2012
    Charlotte, N.Carolina
    what is your companies policy on this?
    don't know?
    ASK.
    SingingWolf Thanks this.
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    This happened to me one time in Wyoming. So I called the port told'em my situation and they said no problem come in we'll way ya and you can get it right and be on your way.
    Pumpkin Oval Head and Dave_in_AZ Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I would travel a thousand miles to find a CAT scale with 11 dollars in hand rather than travel TO a DOT scale man who probably will write a ticket fine large enough if not greater than the fuel burn over 1000 miles.
    I have sat on scales in the past with some really outrageous violations in the past with weights and sometimes I have had scales opened in my face by the lawman stuck behind me at 16 when he knows darn well I can USUALLY pull that same hill at 22 loaded. That one near Williamsport PA was a smart cookie. Got me with extra pallets in the nose that day. And not too many old iron tractors like mine in that area regularly as well.
    EuropeanTrucker Thanks this.
  5. Dave_in_AZ
    426,118
    Keep your #### wired tight driver. Don't ever hope for the generosity of othets.
  6. bryan21384
    bryan21384 Road Train Member
    15,756
    34,337
    Sep 18, 2009
    Memphis, TN
    It's always a good idea to know what you weigh empty. I know I am about 32500 empty, give or take, based on how much fuel I have. That said, 45500 is my limit. That's usually about the weight of a water load or beer load
    Oldironfan Thanks this.
  7. kindastupid
    kindastupid Light Load Member
    53
    89
    Aug 30, 2018
    I've picked up there quite a bit. I hate when the load goes north or south. Not so bad if it's going west across the state. First time I went there I thought I must have screwed up. Weird place for a plant that size & the amount of truck traffic on that tiny road.
    tucker Thanks this.
  8. FozzyNOK
    FozzyNOK Road Train Member
    2,481
    3,824
    Jul 18, 2007
    Oklahomistan
    Yeah.. because DOT cops have no idea where any of those roads are..
  9. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    Yes, and don't have things called portable scales! Right here in Virginia the DOT busts drivers all the time with those infernal things almost everyday.
    x1Heavy Thanks this.
  10. Diesel Dave
    9,707
    33,121
    Jan 20, 2010
    Hesperia, Ca.
    You gots to roll the dice once in awhile. Are you in ?
    wore out Thanks this.
  11. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    There is one by old Raton on US 287. Ive had to hop the 18 wheeler up onto those bathroom scales. I hate them. Not so much as the weight (That's not the problem, I usually had a CAT ticket with the load bills, with CAT generally being compared to 19 master scales nationally) the bathroom scales should not be allowed to determine if I am too heavy and have to pay alot of money. You are putting 4 or 5 ton onto a little plate the size of a dinner plate and it's not fair.
