Scaling help, 75' combination with 5 axles.
Discussion in 'Experienced Truckers' Advice' started by Commuter69, May 5, 2023.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    WT:%%%% am I missing?
    On a typical 75' combination with 5 axles
    1st weigh:
    Steer: 13060
    Drive: 28140
    Trailer: 34460
    Total: 75660
    Adjust the trailer axles and return for 2nd weigh ~5 minutes later:
    Steer: 11980
    Drive: 31120
    Trailer: 32540
    Total: 75640
    How in the world am I getting ~2k different weights on my steers?
    WTH am I missing?
  3. Banker
    Banker Road Train Member
    4,516
    14,637
    Aug 19, 2012
    My math shows you took 1,080 lbs off your steers and the second weigh looks good. I am not sure what your concern is?
  4. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    Brakes were on ?? Roll onto to scale softly and shut off in gear if it’s a standard transmission. If not only set tractor brakes ..
    gentleroger and Numb Thank this.
  5. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    Was your mom in the passenger seat on the first weigh?
    I couldn’t resist. Maybe there was an issue with the scale. I’ve scaled back to back within 5 minutes and my gross was a 2k difference between the two. Hard to trust scales. Also possible on the second weigh a little of your steer tire was off the scale.
    Opus and Flat Earth Trucker Thank this.
  6. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Your kingpun is pretty far rearward of drive center?
  7. Long FLD
    Long FLD Road Train Member
    12,874
    53,886
    Mar 4, 2015
    I’m guessing your fifth wheel is rear of center on your drive axles as mentioned above. Adding weight to your drives will take weight off your steer axle if that’s the case.
    singlescrewshaker and AModelCat Thank this.
  8. Diesel Dave
    9,663
    32,738
    Jan 20, 2010
    Hesperia, Ca.
    How many holes did you slide on the rear tandems ?
  9. mustang190
    mustang190 Road Train Member
    2,888
    6,240
    Jan 18, 2011
    Florida Panhandle
    Slide your seat two notches back.
    And hammer down.
    H3R3T1C and Kyle G. Thank this.
  10. Opus
    132,285
    Putting a fatter person on the teeter totter or closer to the fulcrum.
    Old_n_gray Thanks this.
  11. Commuter69
    1,142
    635
    Jul 2, 2014
    My concern is how I'm getting such a heavy weight on the steer axle at first weigh.... I have not had this kind of issue with any other truck before....
    I'm just trying to understand.
    singlescrewshaker Thanks this.
