Scan tool
Discussion in 'Ask An Owner Operator' started by Short Fuse EOD, Aug 12, 2024.
  1. Short Fuse EOD
    2,791
    8,761
    Jul 29, 2015
    Midwest
    Any suggestions on an affordable but yet effective scan tool that can reset ABS traction control codes, change idle RPM settings, change, speed settings, and look up check engine codes for Pete with Cummins.
  3. OlegMel
    OlegMel Medium Load Member
    615
    1,040
    Apr 8, 2023
    Look into OTR tool. They have list of things it can do on their website. It does have a pricey yearly subscription tho
    OTR Performance® - The source for advanced diagnostics
    Another thing you can do is get Chinese nexiq with cracked cumins insite that you can install on a dedicated laptop without internet.
    Short Fuse EOD and kay_ray Thank this.
  4. kay_ray
    kay_ray Medium Load Member
    492
    1,236
    Jun 6, 2019
    You need two different softwares cummins insite and bendix acom or meritor wabco toolbox. Buying them is super expensive but you can find them for free or cheap if you look at right places. You will of course need a laptop and a nexiq usb link to start with.
    OlegMel, Short Fuse EOD and 86scotty Thank this.
  5. Short Fuse EOD
    2,791
    8,761
    Jul 29, 2015
    Midwest
    Thank you gentlemen
    OlegMel Thanks this.
  6. motocross25
    motocross25 Road Train Member
    3,888
    11,943
    Sep 23, 2010
    Overland Park, KS
    At my previous job I was in a loaner truck that had a Bully Dog in it. Now granted this was a CAT but I thought they made them for Cummins. I’m unfamiliar with all their capabilities but I know I could set the speed and idle and other parameters, but I didn’t screw about with it too much to know if it can scan codes. I thought so but I could be mistaken.
    Oxbow and Short Fuse EOD Thank this.
  7. dosgatos
    dosgatos Medium Load Member
    607
    1,311
    Sep 18, 2012
    Bendix ABS blink codes can be read on the dash (tractor abs light on dash) and reset using a pin out to ground. Find the PDF for your ABS unit online and the schematic and instructions and blink code error messages will be in the document. Free.
    Insight from Cummins is 770/year for pro. No limits works on any engine with the correct adapters (hardware extra). Chinese versions available with hardware for half price but they fail after a year or so and you need a laptop that never connects to the internet.
  8. Ridgeline
    22,727
    123,505
    Spend the money and get the right equipment, it may be costly but if you want to bypass the shop with the right stuff, it may be worth it.
  9. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    I wouldn't waste your money on anything except a cracked copy of Insite and a good adapter. Been using Cummins and CAT software for years with a Nexiq interface without issue.
  10. Ridgeline
    22,727
    123,505
    Yeah, there are copies out there that are hacked, and they will screw up the ECM.
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I wouldn't trust my expensive equipment to cheap sh** or cracked sh**
