Scanner / antenna
Discussion in 'CB Radio Forum' started by RockinChair, Mar 19, 2012.
  1. RockinChair
    RockinChair Road Train Member
    5,397
    14,533
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Does anyone run a scanner in their truck?
    If so, what is a good mobile scanner antenna? I've looked at CB shops and truck stops with no luck.
    I realize that scanning may be a hit-or-miss deal for you OTR folks, but I run the same areas of South Texas all the time. I'd like to put my Uniden BCT8 in the truck so I can hear the law enforcement frequencies and the weather bands.
  3. 3 Dog Nite
    3 Dog Nite Light Load Member
    114
    122
    Mar 14, 2010
    Southeast, TN
    You better check the laws where you run. Scanners with law enforcement frequencies are illegal in most states. NY in particulat you can't even have one in the vehicle regardless of which frequencies you listen to.
    Having that antennea will point at you real loud.
  4. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    I got mine in a truck stop. Does't pick up CB freq. as far out as the real CB does, but works better than the one that came with the radio.
    It's just a short wire, maybe 16 " tall.
  5. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    The aw HERE in Florida is you cannot have police frequencies in a scanner UNLESS you work for a agency or you are a licensed HAM .
    Do they enforce it ..... :biggrin_25513:
    In almost 20 years of working for law enforcement agencies I have seen 2 people ticked for them .....
    Also remember many agencies are going digital and many trunking scanners made back 10 years ago or more don''t work with rebanding
    TRUNKING systemms fall into 3 basic types EDACS ( GE ) Motorola and Johnson most scanners will work with them ....
    Texas from what i found has few scanner laws ....
  6. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
  7. TheRoadWarrior
    TheRoadWarrior rocking-n-rollin again
    1,058
    3,155
    Dec 6, 2011
    South Beach Fla
  8. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Our system ( trunking ) can do digital and be coded so that you can't read it...
    Here at the Jail we are UHF ( 460 mhz ) and we did not find any need to spend the extra money ... If your passing through Clearwater give a lissen ....
  9. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Ever hears of a DISCONE ant :biggrin_25513:
  10. KE5WDP
    KE5WDP Road Train Member
    1,601
    1,054
    Mar 11, 2010
    Waskom, Texas
    No point in it really....even if you tried....
