SCR Performance low, engine will derate IN..
Discussion in 'Volvo Forum' started by AlexD13, Aug 23, 2017.
  1. AlexD13
    AlexD13 Light Load Member
    298
    86
    Jun 13, 2016
    Its my Dad, he tends to idle a lot. Regardless, after changing the doser valve and regening, it went away two weeks ago. This time it happend while driving
    KB3MMX Thanks this.
  3. AlexD13
    298
    86
    Jun 13, 2016
    Looks like it was the Harness. Mechanic said thats whats causing the derate and SCR fault
    shreemike and KB3MMX Thank this.
  4. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    The speed sensor should be on the transmission tailshaft. You unplug it and avoid the 5 mph de-rate
    KB3MMX Thanks this.
  5. AlexD13
    298
    86
    Jun 13, 2016
    Again,after 1000 miles today. Check engine and derate light pop up.. anyone know what it can be
  6. AlexD13
    298
    86
    Jun 13, 2016
    Mechanic is saying EGR Cooler is plugged. That is causing it to throw the SCR code. Any input?
  7. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    That is a possibility. Without good EGR flow, this could happen.
  8. AlexD13
    298
    86
    Jun 13, 2016
    But I drive 2 days after getting the truck back then all of a sudden this light comes up. He says it needs to be cleaned
  9. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Think of what you just said. Flow restricted enough to take a couple of days to show itself. There is also an updated EGR differential pressure sensor with venturi tube kit that was introduced a couple of years ago to address flow issues. I can post kit part# tomorrow morning for you.
  10. AlexD13
    298
    86
    Jun 13, 2016
    Well first time we drove an entire week.. after changing doser Valve and regening, it went away for week.. then we changed the harness and regened and it was good for 2 days. Hoping third time is a Charm.. cant keep going back to the shop for this
  11. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Seems to be a common theme
