SCR Performance low, engine will derate IN..
Discussion in 'Volvo Forum' started by AlexD13, Aug 23, 2017.
  1. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    5348 its not a nox code, i believe nox codes are 3226 and 3216 for output and intake.
    KB3MMX Thanks this.
  3. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Sorry 5348 wasn't that code but he is saying tempurture is Showing high which can resault from faulty Nox
    KB3MMX Thanks this.
  4. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    I thought 5348 had something to do with the def pressure, you need to know the corresponding family number to be sure. It will be spn 5348 fmi 1-18 or so.
    Correction, I was thinking of 5443, fmi 7. Carry on.
    KB3MMX and AlexD13 Thank this.
  5. AlexD13
    298
    85
    Jun 13, 2016
    It was 5394
    KB3MMX Thanks this.
  6. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Now this is low efficiency code that is usually most likely caused by nox the biggest ##### to fix.
  7. AlexD13
    298
    85
    Jun 13, 2016
    Just got it back. Ceossing my fingers that #### light doesn't come back. Changed both sensors
    KB3MMX Thanks this.
  8. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Well...these Things (codes/derate) have a Habit of Coming Back.Recommend changing the Def filters (all of them) and doing a long Regen 1000° + for 45 minites.You can "smell the stuff burning out.JMO
    KB3MMX Thanks this.
  9. Chickenhawk33880
    Chickenhawk33880 Bobtail Member
    Oct 22, 2017
    Winter Haven, Fl
    Constantly having trouble with my 10 ISX. Currently in derate mode. Heading to shop on Monday.
    KB3MMX Thanks this.
  10. Typhoon22
    Typhoon22 Bobtail Member
    Hi Alex my name is Edgar, I have same problem 5394 cod,And I am tired to change stuff in this truck still I am getting 5394: If it’s possible you can tell me finally what was the problem in your truck
    thank you
  11. AlexD13
    298
    85
    Jun 13, 2016
    We changed the Nox Sensors
    KB3MMX Thanks this.
