SCR Performance low, engine will derate IN..
Discussion in 'Volvo Forum' started by AlexD13, Aug 23, 2017.
  1. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    What’s the fin code and what have u changed so far
  3. RoadtoEmmaus
    RoadtoEmmaus Light Load Member
    100
    44
    Apr 20, 2014
    Hey fellas,
    I was having intermittent ACM fail/Scr fail derate in so much time.
    Codes keep changing but last ones I had now are SA 16 P111186
    and U029D.
    The last , if I read the manual correctly has to do with the 1st Nox sensor but what is the 111186?
    Would the Nox sensor being bad also give me the message that the ACM failed?
  4. AlexD13
    AlexD13 Light Load Member
    298
    86
    Jun 13, 2016
    What was the issue?
  5. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    Did NOX sensors helped or you still dealing with the same problem??
  6. AlexD13
    298
    86
    Jun 13, 2016
    Mine ended up being the same thing
    KB3MMX Thanks this.
  7. Newto Trucking
    359
    226
    Dec 26, 2013
    NE Illinois
    So the code came back, right?
    What’s the mileage on your truck right now?? Are you out of Midwest??
  8. AlexD13
    298
    86
    Jun 13, 2016
    No It kept coming back on because they were changing the wrong parts
    KB3MMX Thanks this.
  9. Newto Trucking
    359
    226
    Dec 26, 2013
    NE Illinois
    So do you still dealing with the same problem or you fixed it??
  10. RoadtoEmmaus
    100
    44
    Apr 20, 2014
    I started another thread here: 2014 780/D13 Exhuast temp/ACM/SCR, what?!
    But basically all the whole system goes out of whack if one little component fails.
    In my case it turned out to be a bad exhaust temperature sensor, the one on the bottom of the dpf next to the Nox sensor, and a bad DEF injector valve. So about 480 bucks in parts and about 2 hours doing it myself since I have never done it before.
    If there is no temp reading on any of the sensors, the ACM will "fail". If the acm fails, you will get derated. So it sounds really bad and can scare the heck out of you. I had ACM fail, SCR fail messages and people telling me the def pump was bad or the ACM module was bad..but if you go to the above link you will see some pictures I took , all of them individually will cause all these fail warnings and derate the truck to 5 mph..crazy.
    KB3MMX Thanks this.
