SCR SYSTEM FAULT
Discussion in 'Volvo Forum' started by AlexD13, Aug 6, 2016.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hello Everyone, I am stuck in Phoenix.. Dash shows, SCR System Fault, Engine will Derate in <60 mins.. please help me.. Dealer says they cant take me in til Monday.
  3. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Could be a number of things... NOX sensors could be reading insufficient catalyst conversion efficiency - which could be as simple as replacing the air filter up to requiring the SCR to be replaced. DEF doser could need service, or some component of the DEF system (such as a heater hose) could be faulty. Could be a problem with the DPF... the dash messages are just there to let you know something is amiss... they don't really do anything to diagnose it further, such as give you PID/SID. Maybe try to find another repair shop is about all there is to suggest.
    KB3MMX and j_martell Thank this.
  4. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Did the def gauge works ????
    KB3MMX Thanks this.
  5. AlexD13
    298
    85
    Jun 13, 2016
    Yeah, it was showing half.. Little over half. I just got the truck towed to the dealer. They said it will be til Monday night til they check it out. Im just annoyed. Already paid $5100 for a new turbo this week
    KB3MMX Thanks this.
  6. CoyoteExpress
    367
    173
    Oct 29, 2014
  7. AlexD13
    298
    85
    Jun 13, 2016
    Not sure, my Driver is figuring it out . But the derate mode was on. Wich sucks because I had no time to drive to dealer. Hopefully it isnt something huge
  8. WitchingHour
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    You won't get a fault code off the dash. Unfortunately, you're kinda at the mercy of the dealership until they can plug in and get the codes.
  9. AlexD13
    298
    85
    Jun 13, 2016
    Ya i figured, They said they will look at it Monday evening so Im renting a car to go back home to La.
  10. CoyoteExpress
    367
    173
    Oct 29, 2014
    Unplug the speed sensor at the end of tranny so the timer stop normal and its possible to roll to the shop.
  11. WitchingHour
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Investing in a ProLink might not be a bad idea. It's not the same as having the proprietary software, but it can give you the PID/SID and perform some command functions across a range of vehicles.
    KB3MMX Thanks this.
