Scrappers... Best way to...
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Aug 26, 2020.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Didn't know where else to post this. I figure somebody here knows a bit about scrapping.
    I have several radiators to scrap. How is the best way to prepare them for the most money?
    I also have hundreds and hundreds of feet of wire that is coated.
    Is there a way to strip it or do you just take it as is?
  3. Dale thompson
    5,456
    47,233
    Nov 20, 2013
    commerce twp,mi
    Just put the wire in a burn barrel.
    Rideandrepair and Hulld Thank this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Put the wire in a barrel and burn it, a little old oil helps. Radiator cores are generally just hauled in as is.
    Rideandrepair Thanks this.
  5. Colt6920
    Colt6920 Light Load Member
    178
    263
    Apr 28, 2017
    DO NOT BURN WIRE!
    Most yards WILL NOT PAY for burnt wire, unless it is proven to be from a house fire.
    Too many meth heads that steal and burn wire to prevent identification of source.
    It is also illegal to burn wire in many places.
    Plus, after factoring the lost insulation weight and the downgrade in copper quality (burnt wire is dirty copper at best if they even buy it) it may come out as a wash.
    Rideandrepair and 201 Thank this.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Isn't wire with the insulation still on not generally wanted by scrap yards? Been a few years but the last time I did anything with wire they'd take it with insulation on but they wouldn't pay you for it, same with aluminum cans.
    Dino soar and Rideandrepair Thank this.
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,713
    24,437
    Dec 15, 2007
    Northern Indiana
    Take the radiators as is, unless they have some brass fittings or such, I don't deal with wire, per se, I would probably take it as is.
  8. Colt6920
    178
    263
    Apr 28, 2017
    That may have been when scrap copper wasn’t worth ####. Yards will absolutely buy insulated wire, but they will pay less. Beats nothing for burnt wire.
  9. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    This was 7 or 8 years ago, they paid for burnt wire, but then we only had 25 or 30 pounds worth.
  10. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    I know a guy with wire stripper. If your around sw mn I could help u out
  11. 201
    201 Road Train Member
    12,791
    26,320
    Apr 16, 2014
    high plains colorado
    Poor guy, down to turning in copper wire,,:biggrin_25513:, things are bad all over. I knew a guy that did that, had a bunch of scrap wire from construction sites,,took a drill, and a razor blade, and stripped the wire that way. Burning it off contaminates the copper. Once, I hauled a load of "copper chops", they called them. It was like 20 palletainers of these copper punchings, like dots. Seeing what copper goes for per pound, , I figured 40K pounds was the most valuable load I ever hauled.
