Sdp cat
Discussion in 'Ask An Owner Operator' started by Yord, Dec 12, 2024.
  1. Yord
    Yord Bobtail Member
    4
    5
    Dec 12, 2024
    I have a Cat SDP engine that is using oil. I would like opinions on whether it is worth repairing this engine or buying another Cat that is not an SDP and repairing it.
  3. abyliks
    abyliks Road Train Member
    4,200
    9,963
    May 2, 2010
    ludlow MA
    Pretty sure the block is the same from mbn on up, it’s the emissions garbage that ruined the SDP
    Yord, broke down plumber and Oxbow Thank this.
  4. 77fib77
    77fib77 Road Train Member
    11,934
    79,485
    Jul 7, 2010
    St Louis
  5. Cat sdp
    Cat sdp . .
    21,340
    76,518
    Apr 8, 2012
    Orion's Belt
    If its rebuilt properly it can be a very good piece….. But you need someone that knows what to do …
  6. Yord
    Yord Bobtail Member
    4
    5
    Dec 12, 2024
    I have doubts about buying another engine or repairing this one. Everyone tells me that they are bad. Mine has 650,000 miles and consumes a lot of oil.
    broke down plumber Thanks this.
  7. Diesel Dave
    9,876
    34,481
    Jan 20, 2010
    Hesperia, Ca.
    If you castrated it, it will be fine like any yellow motor. I know of 2 that it did wonders once it was done.
    Yord and broke down plumber Thank this.
  8. snowwy
    snowwy Road Train Member
    20,620
    13,341
    Jul 6, 2009
    If it consumes alot of oil. It probably has alot of blowby.
    I once drove a 99 cat motor that started consuming at 175k. Cat is famous for undersized pistons. The top compression ring on all 6 pistons was broke.
    That particular motor had the blowby vent on the side of the motor where oil was dripping out. Cats solution was to remove the hose and block it off with an oil fill cap. Swap the middle valve cover for a vented valve cover and hook the hose on to that. It fixed the oil loss problem. But still consumed oil.
    Excessive blowby also dilutes the oil to the point you lose oil pressure.
  9. Long FLD
    Long FLD Road Train Member
    13,126
    55,141
    Mar 4, 2015
    I would rebuild it and make it not an SDP.
