seat install
Discussion in 'Freightliner Forum' started by jjranch, Jul 9, 2014.
  1. jjranch
    jjranch Road Train Member
    1,223
    414
    Jan 26, 2008
    Shelbyville, TN
    I purchased a elite seat from Freightliner that requires A adapter plate and was wondering how it gets installed I am the one to do it myself to save the 265 labor cost.
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Are you talking about that riser that comes with the seat? I've put one in a Pete 379 and FL Classic. I did not use that riser. I just drilled holes in the base where I needed them.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Usually is just bolt the adapter plate to the 4 bolts in the floor, then the seat bolts to the adpater plate. You may have spacers to make up the difference of the thickness of the carpet or floor matt, so make sure they're all there.
    Do not try to drill holes to make the new seat bolt to the floor, the bolts go into a crossmember for strength. I've seen people do this and the seat is bolted to sheet metal, not so safe in an accident.
    jjranch and CondoCruiser Thank this.
  5. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I should be more clear. I did not drill holes in the floor.
    icsheeple Thanks this.
  6. jjranch
    1,223
    414
    Jan 26, 2008
    Shelbyville, TN
    It has the existing metal plate that the seat is mounted to but freightliner said I needed an adapter plate. I don't know if I need to remove the existing plate and put the adapter in its place or set the adapter plate on top or bottom of the existing one.
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    I took out the riser and slider track and bolted the suspension right to the floor to get as low as possible and still have useable suspension. In an accident I don't expect to survive so I drive more careful.
  8. jjranch
    1,223
    414
    Jan 26, 2008
    Shelbyville, TN
    It is the EZ rider adapter plate with the tether straps.
  9. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    What's in the truck now should all come out from the floor up. The new seat should have it's own riser and stroke. The adapter plate is just to line up the bolt holes on various trucks which I think Freightliner is 1/2" off which is why you need the adapter plate.
    jjranch Thanks this.
  10. jjranch
    1,223
    414
    Jan 26, 2008
    Shelbyville, TN
    Thanks i wasn't sure if all of it came out or id have to use it together with the existing plate.
  11. jjranch
    1,223
    414
    Jan 26, 2008
    Shelbyville, TN
    Ok I want to thank all who gave advice it was much appreciated. I got the seat in with the existing plate and didn't need the adapter plate at all.
