Second attempt at the SET UP FOR STRAIGHT LINE BACKING
Discussion in 'Experienced Truckers' Advice' started by Wooly Rhino, Sep 20, 2012.
  1. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    I tried to explain this earlier but they all made fun of me. I am proud of the fact that I can dish it out but cannot take it so you big bullies be nice to me.
    The first thing you are going to worry about when you get on the road is the pulling into the fuel island move. If it isn't, it should be. The truth is, if you can do that, you can do it all.
    If you pull into a fuel island you will see that there are many different slots to chose from. If you want to go into slot 4 and it is on your right and you just pull into it like you do a car slot, you are going to hit the concrete posts for sure. The rear end of you trailer takes the shortest line and will (if the slots are 1, 2, 3, 4, 5, 6, 7, 8) head for slot 5. The concrete post are there because they know a newbie or a Swiftee is coming. What you do is pull past slot 4 and start turning for slot 3. Then when the trailer starts turning you head back for slot 4 and your trailer is directly behind your tractor.
    This is how all set ups for backing are done. Look at the hole you want to back into. Imagine it to be on the other side of the tractor and set up like you are pulling into the slot. Then just back straight into it.
    There, I said it. Make fun of me. You big bullies.
    123456 Thanks this.
  3. dptrucker
    dptrucker Road Train Member
    4,707
    3,250
    May 14, 2012
    adelanto,ca.
    #### wooly..when i read the title..thought you was asking how to back straight line and saw that you,ve been atrucker for 7 years.was gonna bully you on that till i read the whole article. lmao! btw...good suggestion
    Wooly Rhino Thanks this.
  4. dptrucker
    4,707
    3,250
    May 14, 2012
    adelanto,ca.
    oops ..guess i used the wrong word lol. use dang instead
  5. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Most important part of backing, isn't actually backing. It's the Setup.
  6. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Hundred twenty six dollar tractor/trailer in 1987, Scratch my paint, You will be driving a go cart @ a shopping mall.
  7. Powder Joints
    8,019
    8,482
    Sep 25, 2007
    Rosamond, SoCal
    Im confused. Your trying to back into the fuel islands.
  8. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    he was using the fuel islands as an example and you would have to image a 180 for backing into a slot.
  9. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    Huh???????
  10. driverjoe
    driverjoe Light Load Member
    125
    33
    Feb 28, 2010
    Well if you were not confused you are now? But whatever works for you then thats ok.
  11. TruckerSue
    TruckerSue Light Load Member
    178
    50
    Aug 28, 2012
    MISSOURI
    Actually if u can't pull into a fuel island you probably shouldn't attempt backing up. LOL
