Secondary air completely gone.
Discussion in 'Commercial Truck Forums' started by Yagbt, Jul 12, 2019.
  1. Yagbt
    Yagbt Bobtail Member
    6
    Jan 27, 2019
    Hi,
    I'm a 3 year driver just got my truck last year. After fueling at a flying J that has no garage my secondary air went completely to zero psi. Primary holds about
    78 psi. What could be causing this? Help.
    I noticed a small round black tank under my truck that has a filter on it and it spits out some air with a small amount of liquid with it fairly often could this need a new filter?
  3. Ridgeline
    22,730
    123,538
    Get it towed to a shop or call a mobile repair service.
    Roberts450 Thanks this.
  4. Opendeckin
    Opendeckin Medium Load Member
    504
    1,402
    May 20, 2018
    How do you not know what an air dryer is after 3 years?
    Roberts450 and buddyd157 Thank this.
  5. Yagbt
    6
    Jan 27, 2019
    Do you have a suggestion?
  6. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    What he said. I’d start with mobile repair. It’s likely something simple and you’ll save money and time.
    Let us know what you end up doing.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Yer OOS then and there.
    Find a shop big enough to deal with your problem.
    I might have a few ideas from my own experience losing both Pri and Sec Air at the same time over dinner. (Air Compressor burned up...)
  8. frito bandito
    frito bandito Light Load Member
    124
    457
    May 31, 2019
    What engine manufacturer? If it's a cummins it could simply be the unloader valve is stuck. Mine it doing me like that right now. It's fine on the highway and dry climates but gets persnickety when there's no boost being made. Cummins has a procedure to 'unstick' it and I need to do that again next time I'm home.
    If you notice it going down often while driving check the cabin air bags for holes.
  9. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Guessing games are fun. It's a Volvo right!!! I know it's a Volvo!!
    Bean Jr., Opendeckin and frito bandito Thank this.
  10. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    now, you get 3 guesses as to the color of this alleged Volvo
    Bean Jr. Thanks this.
  11. Opendeckin
    504
    1,402
    May 20, 2018
    I'm gonna go with white...
    Don't think I'm gonna need the other 2 guesses.
