Tine to be out of o/o for a while/forever.
2010 48x102 reitenour maximiser spread axle flatbed
Located, Elkhart, IN
Not abused, but not a show-trailer
New brake pads all around, new calipers/rotors front axle late 2024 (all 4 inner and outer hub seals at the same time, no seepage/leakage), early 2025. (And other 2 rotors and calipers changed 2021)
Tires, 2 brand new (27/32) , 1 a year old, the rest legal but you should change them.
Have the clip in coil rack holders for shotgun, bunch of jhooks (about 20)
2 sideboxes, with or without equipment, (serviceable tarps/straps)
11 sliding winches driver side, 3 pass side
Auto tire pressure fillers all axles.
5th wheel cassette not replaced since i bought it in 2020, but not missing the bolts, not bent and little to no corrosion jacking
Axle mounts no corrosion jacking, tracks nicely
Previous owner had glas/stone aframe holes and reinforcements drilled/added for hauling glass/granite aframe direct bolting.
Rub rail solid, pre-"me" repairs exist and some arent gorgeous but held solid the 5ish years i ran it.
Weight equipped for service about 9500, paired with my 96 stretched midroof t600 loaded to the gills with equipment/tools had empty weight of just under 30k with full tanks, the 98 short wheelbase t800 was 28.5k empty and full tanks
Parked since june 2025
Clean title in my hand ready to sign
Ideally id like to see 18000 which i know is high, but make a reasonable offer via pm (including an email or phone in pm would be wise if youre serious)
(Getting rid of the trucks too, postings to come)
(10 pic max limit)
Selling: reitenour2010 maximiser
Discussion in 'Trucker Forum Classifieds & Trading Post' started by skallagrime, Dec 17, 2025.
