Look on each switch. You’ll see NC or NO. Followed by a part #. NC#### is the Low air pressure switch. ( Light and buzzer) Normally closed,( light and buzzer on ) once air builds up it opens at 65psi they both go off. Likewise if air drops, below 65lbs, they both go off to alert you of low air pressure. NO#### is brake switch. Normally open, hit brake pedal, or Trolley Bar, closes at 5lb pressure, Brake lights come on.
