Ok, I'm seriously frustrated here.
I've got a 2004 S60 14l with (I assume) stock primary and secondary spin on fuel filters, with a small shutoff ball valve after the secondary filter housing. This ball valve is shot. The stem rocks from side to side and the packing is gone, to the point I suspect the truck may be sucking air under heavy load. I was poking around this morning and bumped the valve handle while the motor was running, and got sprayed with diesel.
Ok, time for a new valve. WTF are the out ports in this filter head threaded with?! They're not SAE NPT, compression or flare threads. Are they metric? AN-something? The fuel line ends seem to be 3/8" NPT. I can't find an OEM shutoff valve to save my life so I was planning on replacing with a standard full port quarter turn ball valve. Only problem is those threads. Smaller bore than 3/8" NPT but similar thread pitch and spacing. Oh, and the valve itself is odd, has some sort of steel bushing with a washer and O ring, on the side that faces the filter housing. This bushing is stuck and cross threaded. I don't know what the deal is but I'm about to have a local machine shop drill and tap the housing to NPT if I can't find another solution.
Ideas? I can't be the only one who's run into this. Will post pics of offending parts tomorrow, it's dark out under the shade tree now![]()
Series 60 fuel system woes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JPenn, Apr 10, 2014.
I just got one of the shut off valve from freightliner dealership this winter they had no problem my engine is same year as yours. Only problem I had was getting a fitting that cracked on primary filter base I ordered three different ones never got right one so I put a cat filter base on use a cummins filter without stand pipe in it and got rid of steel line between filter and fuel pump I used a braided style fuel line with an fittings only reason for valve is when you change fuel filters because detroit don't have a primer pump like cats do so it's not really needed. I was having a hard time starting truck it was sucking air and losing prime that's why I did what I did. I think detroit gets there fitting from somebody hand making them with files so that no two are alike.
JPenn Thanks this. -
Think I'm going to put a Davco setup on eventually, just broke under load on this one (thankfully hadn't picked it up yet).
What size AN lines did your setup use? I'm curious...also do you have any pictures? -
The fitting if it has an "o" ring and a washer with a lock nut it is called a Boss fiting it is used in hydrolics, Cat uses it in a lot of plugs and fuel fittings.
Well, thanks to someone else's ham handed pipe assembly skills, I now need a new filter base as well. Apparently the Boss threaded end (thanks JohnP3!) was cross threaded into the filter housing and wiped out the first 4 threads. That explains why it was so difficult to get off...
I ought to ditch all the stock stuff forward of the tanks, install a Davco, and run AN lines for everything else. At least the fitting sizes and threads might be consistent then. -
davco's can be found at a very reasonable price on - bay
The Davco system is my very favorite upgrade that can be done, you have only the one filter, and you never waste the time or money changing a filter that does not need it. if you get a bad load of fuel you know it and can advise the dealer. The water drain is easy and very efficient, you do want to buy the wrench. We use to install the 7 micron filter some guys used the 2 micron, they had their own fuel storage tanks and filtered it. Even when they had to get fuel from the local suppliers they changed the filters maybe once more each year than the guys that ran the 7's.
Just a thought! -
I see Davco 382 setups going for mid $200 range on eBay. Think I'd like a heated base though since I run northeast. Almost every truck I've ever driven has had one, except for my stint at FFE. TMC had them and provided us with a few spare filters, a wrench and a drain pan.
I just bought a new cap for my davco. the style has changed. the new cap needs no wrench. it is hand tight/hand loosen. I got it as a spare, cause my older cap that needed the tool to remove & tighten broke off a few teeth.
