Series 60 oil consumption
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by trucker21r, Jun 19, 2019.
  1. trucker21r
    trucker21r Bobtail Member
    17
    8
    Jun 19, 2019
    Detroit rebuilt a 12.7 series 60 roughly 200k miles ago. Lately it's been using about 3 gallons every 2,000 miles. There is no loss of power, runs great. No smoke from the exhaust. The crankcase breather puts out a heavy, steady stream of air/smoke. All the guages are within normal operating conditions. Any help I appreciate.
  3. trucker21r
    17
    8
    Jun 19, 2019
    Sorry, the engine I believe is a 2003
  4. Banker
    Banker Road Train Member
    4,534
    14,760
    Aug 19, 2012
    Did Fitzgerald build it by chance? Just curious because their engines that go bad, tend to go around 200K and some change according to many Detroit shops.
    Intothesunset Thanks this.
  5. trucker21r
    17
    8
    Jun 19, 2019
    No, it was rebuilt by a local Detroit diesel shop.
  6. Banker
    4,534
    14,760
    Aug 19, 2012
    Good luck with it. That’s a lot of oil even for a Detroit. Before my Turbo went out it was using that much, but you could smell it.
    Rideandrepair and Intothesunset Thank this.
  7. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    Don't get too discouraged- a 12.7 detroit wont break the bank- Thats a good affordable motor.
    Start with obvious things- Crawl Under- Rear of oil Pan- Check for oily mess by pan/bell housing- Could be mechanic got lazy with end cap and destroyed main seal
    Also,When you say crankcasae smoke, Thats sometimes an indication of a failed water pump, I dont know if 12.7's weep internally or not, But coolant comes in pushes oil out blowby
    Rideandrepair Thanks this.
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    my 12.7 was using a lot of oil come to find out it was a bad air compressor blowing oil in the air tanks
  9. Rideandrepair
    17,572
    56,926
    Aug 8, 2015
    Bad compressor or turbo can cause excessive blow by.
  10. Rideandrepair
    17,572
    56,926
    Aug 8, 2015
    Check coolant for oil yet? Oil cooler?
  11. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Maybe rings are not seated yet, or bad rings?
