series 60 shutting down
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, May 16, 2019.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    have a series 60 that shuts down and doesn't throw any codes or alarms going off. checked dddl and no codes are present or inactive in the system. truck shuts down when loaded only but bob tailing it can drive around all day with out shutting down.
  3. Milr72
    Milr72 Medium Load Member
    578
    1,419
    Dec 16, 2011
    S W Missouri
    My grandpa had a mule like that! He'd run all over the pasture just fine but hook him to the plow and he'd just stand there! I know this didn't help your problem but I couldn't resist!
  4. Joetro
    Joetro Road Train Member
    2,417
    2,411
    Aug 23, 2008
    Post Falls, ID
    I know it sounds silly, but have you checked the coolant level? Mine did that to me. Drove me nuts until I figured out that the coolant level was just close enough to the sensor to start it, but the truck wouldn't stay running.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Or coolant level sensor
    Joetro, Intothesunset and Bean Jr. Thank this.
  6. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    I have always found that if one shuts off with no codes it is wiring issue to ECM or the ECM itself. Start in the batter box with the small wires with fuses and make sure everything is good there then work for forward. What kind of truck is this?
    Intothesunset and BoxCarKidd Thank this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Always loaded never empty? Ground issue between the engine and frame - battery? Put a small ground wire between the battery and engine or transmission. Does it stop shutting off?
  8. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    A loaded truck build more heat than a bobtail.
    I believe when the thermostat opens on said truck the reservoir may get empty causing truck to shut down? Or an air pocket?
    Is the engine a DDEC 5 ecm 2004-2008?
    Is the truck making a constant alarm ?
