service check engine light
Discussion in 'International Forum' started by rickybobby, Nov 16, 2014.
  1. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    My service check engine light is on. I check my oil and it was low, so i added some oil. Is there anyway i can turn it off? Also, will it be alright to drive it. Its the service light not the warning light. 2006 c13 9400
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I am not familiar with a "service" light on a 9400, or I am drawing a blank here. Does this have an automatic transmission?
  4. rickybobby
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    Yes it's a auto eaton.
  5. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Is the "service" light blinking on the shifter control? If it is, this is indicating a transmission code is active. To retrieve the flash code, start with key on, engine off. Then within 5 seconds, turn the key off then on - twice, (do not start the engine). If no codes are active, it will flash 2 5.
  6. rickybobby
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    I drove it 250 mi and the light went off. Its on the left side of panel.
  7. Heavyd
    7,826
    6,276
    Feb 4, 2009
    I had a look at an operators manual and I can see the "service" light in the left panel near the bottom. I actually think the engine is programmed with a service interval and is turning that light on when it is due for an oil change. It definitely isn't a fault light. Any fault that is detected by the engine will turn on the "Warn Eng" or "Stop Eng" lights. I think the "service" light is maintenance related. Unfortunately, the operators manual doesn't mention this light specifically. As long as everything is working ok and you do not get any other lights coming on, I wouldn't worry about until your next scheduled service. Next time it is in for something, just ask them if they can connect to the engine and see if any service or maintenance intervals are turned on.
    rickybobby Thanks this.
  8. rickybobby
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    Yes i look at the manual and i couldnt find it in there. Thanks for the help
