Set Forward Axles and Shallow King Pins
Discussion in 'Flatbed Trucking Forum' started by ProfessionalNoticer, Oct 23, 2021.
  1. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    What's the advantages/disadvantages of a 48' flat that has the axles moved forward 3' and a 16" kinda setting?
    I was thinking moving the axles forward 3' would help bridge laws essentially making it a 45' but still have the extra 3' of deck space of a 48'. However, the shallow 16" kingpin has me perplexed.
    shooter19802003 Thanks this.
  3. Big Road Skateboard
    7,222
    41,053
    May 2, 2021
    The king pin setting is definitely important on shorter wheel base trucks. Before I picked up my new trailer, my rental had a 30" king pin, and I couldn't push anything more than 6" over the nose.
    New trailer is 24", and has allowed me to haul loa ds that Before would have hit my headache rack
  4. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    I'm used to 30". Wouldn't mind a 24 but it seems like 16" setback is too far. I know I'm probably missing something here.
  5. Tug Toy
    Tug Toy Road Train Member
    7,101
    74,274
    Jul 4, 2015
    Corn field
    When I had my 5th wheel replaced on my 48 I had it moved from 30 down to 18. Gave me more front overhang.
    My new 53 has a 36” kingpin To be Tennasee compliant. ( not my choice but I bought it from TN and that’s the only way they order them). My truck is stretched now so I have plenty of room for 60 or 65’ stuff.
  6. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Easier to move weight onto your steer. Slide your 5th wheel ahead without worrying about hitting bunk with corner of the trailer. My experience has been with concentrated loads like steel but l wouldn't have a deep pin setting if l had a choice. The axles slid ahead will make it more manoeuvrable but make them carry more weight. Shouldn't be a real issue with a 10'1" spread. Plus if you run your 5th wheel way ahead and have a heavy front axle it'll pull weight off the drives too. A lot of multi axle trucks do that. Especially in Mi were multi axle trucks are only allowed 32000lbs on the drives.
    stwik, Ruthless, Oxbow and 2 others Thank this.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    So how does it fit in with a 48' spread that has the axles moved forward 3'?
  8. special-k
    1,523
    3,258
    Dec 27, 2008
    It's in the answer if you read it. The rear spread will be easier to load heavier because it's further up and the steer will be easier to get weight on because of the shallow kingpin And it'll be easier to get around with because it's shorter. Basically a 45 foot trailer.
  9. MACK E-6
    50,173
    239,771
    What law is there in Tennessee regarding kingpin setback?
  10. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Thanks. I did read it but that part just didn't stick for some reason. Maybe I should have my coffee before reading these replies!
  11. kwswan
    kwswan Road Train Member
    2,048
    11,270
    Jul 26, 2009
    mcminnville,tn.
    Kingpin to axle group spacing. I think it's 41 ft from Kingpin to center of front axle.
    MACK E-6 Thanks this.
