Setting ISX injectors during overhead
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by God prefers Diesels, May 27, 2021.
  1. God prefers Diesels
    4,198
    22,267
    Jun 26, 2020
    South Texas
    I know you need a dial wrench instead of a click wrench, but can you use a beam wrench instead? Because I have a little 1/4" beam wrench, and I don't want to drop coin on a dial wrench if I don't need to. Thanks.
  3. Goodysnap
    Goodysnap Road Train Member
    3,782
    9,223
    Jul 12, 2017
    This step is a very critical point in the adjustment. What ever method you choose I would make sure its calibrated.
  4. God prefers Diesels
    4,198
    22,267
    Jun 26, 2020
    South Texas
    I bought that beam wrench a few years back, but I only used it once. Been sitting in my toolbox ever since. What about running the overhead, and just skipping the injectors? In your experience, do they usually need much adjustment?
  5. Inderjit
    Inderjit Heavy Load Member
    773
    739
    Sep 17, 2017
    I don't see why you can't use a beam wrench. Is there a place that can check the calibration?
    The Snap-On trucks usually have a calibration tester.
    God prefers Diesels Thanks this.
  6. Inderjit
    773
    739
    Sep 17, 2017
    While you are in there it might be a good idea to install a tune up kit for the engine brake.
  7. Goodysnap
    3,782
    9,223
    Jul 12, 2017
    I would say you should be Ok. Consistency is the key and not to over torque. Is the in- lbs scale large enough to be precise?
    Maybe buy one of those cheap digital torque adapters to check it?
  8. God prefers Diesels
    4,198
    22,267
    Jun 26, 2020
    South Texas
    Nevermind, it has nowhere near the resolution I need. It's a flippin' 3/8 wrench. Not sure why I had it in my head it was 1/4. I guess the whole question is moot at this point. Thanks, though.
    Nostalgic Thanks this.
  9. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
  10. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    Don’t know if you have done the overhead yet since this post was a few months old but a beam torque wrench works.Just did mine a few weeks ago.Don’t know if you know about Cummins Quickserve which is free and literally shows you how to do everything including a rebuild on the engine.Also if you ever need Insite I have it.
  11. God prefers Diesels
    4,198
    22,267
    Jun 26, 2020
    South Texas
    Oh, I hadn't used my beam wrench in so long, I forgot it was 3/8. I just ended up setting valve lash and called it good. Boy did it need it.
    What do you need for Insite? Just like a 6-pin to USB or something?
