setting jakes n14 celect plus
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 4vmach1, Feb 17, 2014.
  1. 4vmach1
    4vmach1 Light Load Member
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    Hello. The n14 celect plus requires the cummins 3375006 dial gauge to set the jake brakes. Can I use a regular no name brand magnetic base dial gauge I bought from google shopping a few months back to set the adjustment? It's never been used and I'm sure it's not out of calibration. Thank you
  3. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    If you believe it to be fairly accurate the answer is yes. Not many mechanics use Cummins tools, they cost too much and must be special ordered most of the times.
  4. 4vmach1
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    Thanks. Besides snap-on what would be a good dial indicator to buy for future reference?
  5. wore out
    wore out Numbered Classic
    17,518
    218,747
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Central makes pretty decent micrometers and dial indicators. Its vibration and rapid changing temps that get to tools such as that.
  6. 4vmach1
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    So It would be a good practice to purchase or have an expert re-calibrate the dial indicator gauges at least once a year or so?
  7. Poneill.45
    Poneill.45 Bobtail Member
    24
    20
    Jul 17, 2013
    Starrett, Brown & Sharpe, and Mitutoyo are the top of the line brands.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    I have a small magnetic base that I cut the shafts, and use the dial indicator. To test a dial indicator all you have to do is set one, on somthing that bottoms out to say .020 then replace the dial and set to .000 if after adjusting the bolt down till it stops it is at -.020 it is good. I have used the same dial for 40 years never had a problem with it. I buy very good measurement tools. Starrett and Mitutoyo.
    Doing the set evenly, valves, injectors and the Jake's makes the engine run, smooth and the customer remembers that.
    I remove every adjusted and with a shop towel tap it flat on the paper to bleed out the oil and look for a crack, many of them are cracked. I also change every innerspring on every valve set.
    Just a thought!
