Shake when driving
Discussion in 'Questions From New Drivers' started by Jacobsons2388, May 1, 2025.
  1. Jacobsons2388
    Jacobsons2388 Bobtail Member
    6
    Jan 16, 2025
    I get a bad shake when I drive my truck (Volvo 670) around 65mph and it goes away around 67-70 when bobtailing. I have new tires all around on the truck and new front shocks. The back shocks have not been changed I’m assuming since the truck was bought. Iam 2nd owner. My front tires even before buying new ones wore evenly. My backs on the old ones started cupping. Do you guys think it’s the rear shocks since the shake goes away when there is weight or maybe the king pins. Thanks
  3. bad-luck
    bad-luck Road Train Member
    3,539
    6,556
    Nov 16, 2013
    Baltimore, Maryland
    Could be rear bushings, could be a u- joint, carrier bearing, broken spring.
    Rideandrepair Thanks this.
  4. Ridgeline
    22,850
    126,462
    Could also be a bent rim or rear shock problem.
    Could also be an engine issue, but more likely a drive line issue.
    Rideandrepair and Bean Jr. Thank this.
  5. Jacobsons2388
    6
    Jan 16, 2025
    Would it shake all the time if it was the drive line?
  6. Ridgeline
    22,850
    126,462
    yes.
  7. Big Road Skateboard
    7,803
    45,309
    May 2, 2021
    Does the vibration start in the steering wheel or the floor?
    201 and Rideandrepair Thank this.
  8. Rideandrepair
    17,622
    57,028
    Aug 8, 2015
    Cupping or step wear on drives is usually from bad rear shocks. Vibration? New shocks, check the ride height, Volvo has a frame mounted adjuster, two different settings, depending on width of frame rails. As mentioned the rims, and rear spring bushings. Check the whole driveline for play. Starting at transmission tail shaft and yoke, carrier, all U joints, drive shaft and rears yokes. If it’s good leave it alone. Throwing parts at it can be expensive and aggravating. Check the whole front end, Bad engine and transmission mounts are sometimes the culprit when all else is good. If the Trucks over 7 years old. It’s possible.
    201 Thanks this.
  9. 201
    201 Road Train Member
    12,998
    26,816
    Apr 16, 2014
    high plains colorado
    Vibrations are always difficult to pinpoint because there can be so many causes. This^^^ helps. Generally, a shake in the steering wheel indicates something in front, while a shake in the seat, or floor, indicates something in back. A bad U joint usually vibrates under power. Things like bearings or mounts don't "go away" and I suspect a balancing problem. Brake drums, driveshaft, and of course wheels and tires have weights and, I'd start there. The reason it's prevalent at 65, is that's the speed it probably ran for years. A worn engine harmonic balancer I heard, causes weird vibrations too.
  10. Brandt
    Brandt Road Train Member
    4,674
    6,478
    Sep 17, 2012
    I had Volvo with vibration I could not find. Thought it was u-joints but I could only feel it when empty or bobbing. It would come and go way at randomly it seemed.
    it ended up being the Carrier Bearing that is under the cab holding up the drive line. If you or someone can push it up and down my understanding that sign it bad and worn out.
  11. 201
    12,998
    26,816
    Apr 16, 2014
    Johnny Kidd and the Pirates said it best, in 1960!
