Shaky/Vibrating feeling on 6th and 7th gear?
Discussion in 'Questions From New Drivers' started by Lightning01, Jun 15, 2020.
  1. Lightning01
    Lightning01 Bobtail Member
    26
    29
    Mar 7, 2020
    1999 Mack dump truck. So everything else is normal. I start shifting up normally, I get to 6th gear, as soon as I start getting to the end of 6th gear, there’s a very slight vibration/trembling. You can also feel it in the duration of 7th gear. 8th gear it’s very light but not like 6th and 7th. Have no idea what it is. The truck doesn’t feel as smooth like it does in other gears, at high speeds it feels a bit “loose” if that’s the right word. When driving on normal roads, the truck feels like it’s driving on a bumpy road full of small holes. And it feels terrible on roads that are actually bumpy and full of holes, not as easy and smooth as it felt before. You can feel the tremble whether it’s loaded or unloaded.
  3. bad-luck
    bad-luck Road Train Member
    3,480
    6,408
    Nov 16, 2013
    Baltimore, Maryland
    Check the drive train, you may have a bad u join or Carrier bearing. Also it could be possible you have a broken clutch Spring maybe more than one
    Lightning01 Thanks this.
  4. spindrift
    spindrift Road Train Member
    3,235
    12,916
    Dec 2, 2014
    Texas
    I just had my front end aligned and rears shimmed properly. Bunch of other stuff as well. It could be anything wrong along the drive train, front end, bad tires, old Centramatics, a steer that has thrown a weight, torque rod bushings, etc., etc.
  5. Lightning01
    26
    29
    Mar 7, 2020
    I was just in the shop a few days ago as well, new kingpins on all lift axles, 2 new hub oils seals, alignment, new bushings on front and in all lift axles, truck has new tires all over. I can also add, a carrier bearing was replaced a few months back and I think from that time is when the trembling started. But I’ve checked the drive train and the rest of the carrier bearings and they seem fine. After I did the kingpins which was a week ago, the truck felt really smooth for about 3 days and then this trembling came back.
  6. bad-luck
    3,480
    6,408
    Nov 16, 2013
    Baltimore, Maryland
    Take of the clutch inspection plate under the trans. Use a flashlight and check from broken springs? Or try pushing in the clutch in 6th or 7th and see if it stops. Visually inspect the drive shaft, and the u joints on the back rear
    DetroitDudeBro Thanks this.
  7. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I too would say bad center bearing on the driveshaft. Get up on the catwalk and see if you can lift the drive shaft.
    Here is a recent vid of some one that had to replace the center bearing on the driveshaft.
