Share Tips for alleydocking on a Blind..
Discussion in 'Experienced Truckers' Advice' started by dirtjersey, May 10, 2012.
  1. dirtjersey
    dirtjersey Light Load Member
    I have a year of experience and this is definitely one of my weak areas of driving. I would like to improve. Any advice to maks it easier? ( Please dont state the obvious "GOAL" )
  3. dirtyjerz
    dirtyjerz glowing beard pouty kid
    722
    360
    Jun 7, 2011
    Playing in Traffic
    Use your power mirrors on the blindside.
  4. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    Well but it is obvious, get out and look.
    The alley dock will frustrate anyone. One day, you're in first try. The same day, only a few hours later, you're all messed up again.
    Take it slow, stick your head out the window, and watch where you want your trailer to go.
  5. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    sticking your head out the window,
    on a blind back ??
    won't see much !!!! :biggrin_2559:
    Wargames and Onetruckpony Thank this.
  6. Yatista
    Yatista Medium Load Member
    479
    207
    Jan 25, 2009
    Upstate New York
    If you have a window in the sleeper on the blind side use it. If you have spot mirrors on the fenders, use them.
  7. Gizmo_Man
    1,226
    599
    Aug 15, 2011
    Hardly around
    Ah geez.:biggrin_25526:
    In his posting, I did not see "blind", but yeah, it was there in his title.:biggrin_25524:
    My bad.:biggrin_25514:
    Well, if he has the neck of a Giraffe???.:biggrin_2559:
    dirtjersey Thanks this.
  8. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    You can ask someone one the ground to spot
    GOAL then use something as a landmark to not go further if you see it
    Sometimes moving your mirror out a little can make a big difference, depends on the situation.
    kwloo Thanks this.
  9. Kujo
    Kujo Medium Load Member
    442
    168
    Feb 6, 2012
    in the middle
    That and your convex mirror are the best tools you have but still go slow and once the trailer is coming around go check the angle looks good from both sides rather than wait to long. It's easier to fix the angle earlier then later.
  10. vavega
    vavega Light Load Member
    295
    177
    Oct 13, 2009
    maple shade, nj
    set yourself up just like you would on the right side but in reverse, using the exaggerated S move. then practice. got a stop with a big lot that you would normally just back into? spin it around and blind side in. or at the end of the day practice in your yard. you're not going to get better at it unless you practice.
  11. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I agree with vavega, practice. if you fuel up in the middle of the day head to the back of the truckstop and try blindsiding it into a spot with no trucks around. Also, do you understand the concept of over-cutting versus under-cutting ? If you over-cut (your trailer is turning too quickly) usually all you have to do to correct is straighten your wheels and pull up a few feet, then continue backing. If you undercut, you have to almost start over. So it is better to overcut a little bit. Last piece of advice is probably obvious, but I see so many guys do it wrong. You must, must, must start from the best postion available. Leaving yourself room on the left for your truck to swing, but a little room on the right for your trailer to cut the corner as well.
    sidepocket Thanks this.
