She's getting better but....
Discussion in 'Freightliner Forum' started by dajain, Sep 18, 2023.
  1. dajain
    dajain Light Load Member
    111
    135
    Apr 16, 2022
    This should be a quick one for anyone who has the information.
    1999 Freightliner FLD120
    Noticed it when I bought the truck but didn't have time to fix, a bent tie rod.
    Going to get the parts in to fix it but what is the alignment measurement for the truck?
    I'm guessing 1/16th of an inch, toe in but would like to get it right.
    Anyone have that info to share?
  3. Big Road Skateboard
    7,093
    40,235
    May 2, 2021
    1/16" is where i set toe. That doesn't mean it's aligned though.
    Magoo1968 and dajain Thank this.
  4. dajain
    111
    135
    Apr 16, 2022
    I just figured that since I am only asking for the toe in measurement for replacing the tie rod, it would be obvious that it's not getting a full alignment but thank you for clearing that up.
    Wouldn't want any confusion to settle in on this easy question.
  5. Big Road Skateboard
    7,093
    40,235
    May 2, 2021
    Lol. You guys. So simple that you stated
    One would assume you did not know the difference between alignment and toe in.
  6. dajain
    111
    135
    Apr 16, 2022
    There's the key word.... assume
    I asked for the alignment specs for what the measurement should be for replacing the tie rod.
    I assumed that was an easy enough question to not be critiqued, but there go.
    I assumed wrong
  7. Numb
    Numb Crusty Curmudgeon
    4,314
    10,247
    Jan 30, 2012
    Charlotte, N.Carolina
    never assume what the people here will think. :rolleyes: :D
    dajain Thanks this.
  8. dajain
    111
    135
    Apr 16, 2022
    Right?
    I guess I should have been more specific by stating that I know replacing the tie rod only effects the toe in measurement and the factory specs I am asking for is only for the tow in and that I know this is not a full alignment as I am only replacing the tie rod.
    I guess I shouldn't assume a simple definition and answer should be so simple. haha
    Numb Thanks this.
  9. dajain
    111
    135
    Apr 16, 2022
    So, What are the factory specs for the toe in measurement on a 1999 FLD120?
    Can I assume this is a simple enough question that is worded to everyone's liking?
    o_O:)o_O
    Numb Thanks this.
