Shift finger rail position
Discussion in 'Volvo Forum' started by Helowrenchturn2, Jul 26, 2013.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    I have this code today. Does it have to do with xy shifter?
  3. nikmirbre
    nikmirbre Road Train Member
    5,626
    10,455
    Jul 27, 2011
    High Point NC
    I use to have that code in my Volvo....it happened when the red transmission light on the buttons was flashing and it seemed to be stuck in neutral.....I turned truck off and it reset.....I think later on down the road I replaced the xy splitter and something else and it went away...
  4. Helowrenchturn2
    484
    140
    Apr 23, 2013
    What kind of money is that thing?
  5. nikmirbre
    5,626
    10,455
    Jul 27, 2011
    High Point NC
    I think it was 1500$ or so installed at vovlo....
    Helowrenchturn2 Thanks this.
  6. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Thanks. How the freightliner doing?
  7. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    If I am not mistaken the part was around $6-700 and its not hard to install. Would take the average mechanic about 30-40 minutes to install.
  8. Helowrenchturn2
    484
    140
    Apr 23, 2013
    I'm getting a code 51 on the tranny. This is a direct code for that sensor. Just got a call back from the dealer and was informed you can buy the replacement kit just for that position sensor for $85. I think in gonna go that route first to see what happens
  9. Damage
    67
    17
    Jan 13, 2012
    Newark, Nj
    Good luck with it. Hopefully it does the job. Its probably worth the risk of it for a fraction of the cost. I dont know what year your truck is but on our 2006 with ultrashift. There was an update to the XY shifter if you havent had it changed out it really needs to be. The older ones the brushes wouldnt make contact once they were worn a bit in the XY motor(The wire to the brush was to short from the manufacture.)
  10. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Mine is a 2007. Had the dealer call eaton yesterday and they said there were no recalls or anything for mine
  11. Damage
    67
    17
    Jan 13, 2012
    Newark, Nj
    On ours it wasnt technically a recall...it was what they called an "updated" part. The difference being is if it is out of warranty they arent going to swap it out for free. 2007 is about the time that the new xy shifters started showing up though. So hopefully yours has the latest one in it. The only way I can tell them apart is the new ones have a green dot on one of the canisters if I remember correctly. But if yours shipped with it, it may not have the green dot on it.
