Shifting a 10 speed uphill
Discussion in 'Questions From New Drivers' started by montrose818, Sep 7, 2018.
  1. montrose818
    montrose818 Light Load Member
    93
    36
    Apr 9, 2018
    Hi. I am having big issues shifting a 10 speed when starting out on a hill (lets say 10-15% grade?). The engine's sweet spot is around 1200 rpm. I have tried everything, but cannot shift 2 to 3, 3 to 4, 4 to 5. I tried noting the RPM its at in each gear at a certain MPH, but once I reach it, I can't seem to put it in the gear it needs.
    At what speeds / RPMs should I shift from each one, and what should my entry be?
    I am double clutching. Thank you very very much!
    TravR1 Thanks this.
  3. The_Flying_Dutchman
    The_Flying_Dutchman Light Load Member
    108
    119
    Nov 8, 2016
    Jesup, Iowa
    Unless somebody is forcing you to double clutch, learn to float ASAP. You don't have time to be messing with double-clutching starting out on grades. It takes too much time. The instant you let off the throttle you are loosing speed and rpms in a hurry. You gotta shift it like you're mad at it. As soon as you let off the throttle, float it out of gear and right into the next one as quick as you can. You are missing gears because it's taking you too long to shift double-clutching.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,986
    19,040
    Nov 1, 2010
    Burnsville, MN
    I don't think I have ever been on a 10% grade, not to speak of a 15%.
    And if you are trying to upshift on a grade and can't catch a gear, maybe it would be wise to just take it slow and steady until the top.
  5. montrose818
    93
    36
    Apr 9, 2018
    Ok I will try that, thank you. I did try bringing the RPM's up a bit when putting it back into gear, but like I mentioned, no dice. I am new, so I was double clutching to avoid stress on the transmission.
    okiedokie Thanks this.
  6. montrose818
    93
    36
    Apr 9, 2018
    The hill grade in question is to the truck yard, I am only trying to get it up to 10-15mph, which is what everybody else makes it up at. Right now I start in 5th or 6th right before the hill and hold it up. I had to start in 3rd once and ride it up so slow, there was a line behind me by the time I got up
  7. AModelCat
    164,846
    Are you trying to pull it out of gear at 1200 to upshift? It could just be that its too low of an RPM to be able to catch the next gear before your engine hits idle speed. Have you tried shifting it at a higher RPM?
  8. wore out
    wore out Numbered Classic
    17,343
    215,391
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What's wrong with a line behind you?
    Don't worry about the crowd, or what's said. Do what you gotta do to make it to the top every time.
  9. 201
    201 Road Train Member
    12,791
    26,323
    Apr 16, 2014
    high plains colorado
    Gotta be quick, with the stick,,,,,;)
  10. singlescrewshaker
    4,868
    42,611
    Dec 31, 2017
    Little Havana, FL
    You will loose speed real quick while shifting on grades. To help combat this I turn on my 2 cylinder jake switch. Helps bring the revs down quicker to grab the next gear. Rope it out to 17-1800. No clutch slip out of gear, listen to the engine revs drop & slip into next higher gear. Throttle up & repeat..
    My tach is super lazy & doesn't really work so I learned to shift from engine sound, & transmission feel. You can learn that too, & it will make you a better operator.
    When driving on the flat start trying to shift with no clutch or looking at the gauges. Go by engine sound & feel of the stick & you'll have it in no time.. Good luck.:cya:
  11. JLMooreKCMO
    JLMooreKCMO Light Load Member
    282
    296
    Jun 8, 2007
    Make sure the Jake Brake is off.
