Shifting a freightliner century
Discussion in 'Trucking Schools and CDL Training Forum' started by Luke700, Jan 11, 2021.
  1. Luke700
    Luke700 Light Load Member
    57
    26
    Oct 14, 2019
    new driver here for me the hardest gears are 1-5 why is it when I’m in gear the truck be shaking so much ? What’s the best advice for shifting those lower gears? Best rpm etc etc 14L Detroit
    truckdriver31 Thanks this.
  3. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    If the truck is shaking it's called a freightshaker for a reason. Are you lugging the engine?
    What's the rpm when it's shaking?
  4. Luke700
    57
    26
    Oct 14, 2019
    Yeah think I’m lugging it sometimes ill have to go into 4th instead of 3rd I guess because my speed is too high for 3rd i don’t know. How fast are you suppose to shift those lower gears
  5. LDLWells
    782
    1,219
    Jan 14, 2019
    Depends on the transmission. I'll assume ten speed. If I remember right and I probably don't those Detroit 60s liked a little higher rpm. Don't upshift when you're at 1300, bump it up to 17 or 18
  6. Luke700
    57
    26
    Oct 14, 2019
    Yeah 10 speed. Alright I’ll give it a try thanks
  7. Brandt
    Brandt Road Train Member
    4,626
    6,360
    Sep 17, 2012
    Don't shift at high RPMs you will never get it in gear. You want the exact opposite. You shift at 1,000 RPMs or less, in low range. You do this because you don't have to match the gears and it stop all that shaking. You don't need 500HP to get rolling from a stop.
  8. Luke700
    57
    26
    Oct 14, 2019
  9. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    why you shifting less then 3rd anyway. you can start off higher. the jerking is from you starting off too low
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
  11. HiramKingWilliams
    HiramKingWilliams Heavy Load Member
    806
    1,291
    May 15, 2019
    State of Jefferson
    On flat ground.....my rig likes 1,300-1,500 for gears 1-6, and 1,500-1,600 for 7th. 8th-10th aren’t as picky.
