Shifting after 11 years
Discussion in 'Questions From New Drivers' started by DoubleO7, Aug 23, 2015.
  1. DoubleO7
    DoubleO7 Road Train Member
    1,532
    1,598
    Aug 21, 2015
    Southern Illinois
    After over 11 years off the road, I am scheduled to start orientation with Swift soon. Has anyone here been off the road for a significant period of time and returned? I will have to do a road test the first day, and I am a little concerned about shifting. When I was on the road, I drove trucks with 10 speeds, Eaton Fuller of Rockwell. Swift has 10 speeds.
    Does anyone know what transmissions Earl Henderson runs? I will add that I do not really want to go to an automatic company. There is something about running a manual that keeps a driver engaged and alert. That's how it seems to me.
  3. Voodoo Pyg
    Voodoo Pyg Oink! Oink!
    607
    760
    Jan 25, 2015
    Corpus Christi, Texas
    Have you gone to the trucking truth website? You can also speak with a recruiter or visit the SWIFT website. From my experience most of them are using between 8 and 10 speed transmissions now.
  4. brian991219
    brian991219 Road Train Member
    3,034
    6,241
    Aug 10, 2013
    Lords Valley, PA
    The biggest difference in shifting today's modern trucks is the power band in the engine. If you came off the road 11 years ago you were used to a higher shift point than the new trucks use. Just keep the rpm low and you will do fine, it will come back to you. They are not going to expect you to be perfect the first time out on the road test after 11 years off the road.
    slick mick, Voodoo Pyg and DoubleO7 Thank this.
  5. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    The question is how good were u before getting off the road.shifting is like riding a bike ,you only need to learn it once.
  6. DoubleO7
    1,532
    1,598
    Aug 21, 2015
    Southern Illinois
    That's good to hear. I would estimate that I had well 0ver 150,000 miles driving 10 speeds. I only used the clutch to start and stop and floated the rest.
    Voodoo Pyg Thanks this.
  7. RetiredUSN
    RetiredUSN Medium Load Member
    694
    991
    Jan 9, 2015
    If you are floating the gears, it is all the same. Might be some rpm/road speed difference, but you will feel it wanting to slip out of gear anyways.
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    I came back after 10 years. Shifting wasn't the problem but I was a bit rusty on backing.
    slick mick Thanks this.
  9. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    I came back after 25 years. Shifting machines is fun and easy, and that was no problem. It was running over all those cars that really bugged.
  10. Starboyjim
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    I guess I must have missed something. Again. I didn't get the relationship between Swift and Earl Henderson? A little help here?
  11. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    Forgot how to use the steering wheel. Hmm.
