shifting an 8 speed
Discussion in 'Questions From New Drivers' started by orferd, Mar 21, 2012.
  1. orferd
    orferd Bobtail Member
    19
    California
    Could someone please give me the rpm range and speeds for upshifting and downshifting an 8 speed. Im pretty sure the rpm range is 1000-1500 but im unsure of the speeds, especially for downshifting. Ive only driven a 10 speed but ill need to know an 8 speed for my road test. Thanks a ton.
  3. Round2
    Round2 Light Load Member
    268
    90
    Feb 14, 2012
    WA
    Should be 400 rpm splits. Try shifting at 900-1300 on the low range and 1100-1500 on the high side. 900-1300 on your drops.
  4. xlsdraw
    xlsdraw Road Train Member
    4,258
    9,305
    Nov 17, 2010
    Lake Alfred, Florida
    When I change trannies I just tend to trust my ears. They'll tell you what to do if you're tuned in to the engine like you should be.
  5. Round2
    268
    90
    Feb 14, 2012
    WA
    Series 60's sound fine at 14-18 but the MPG's suck up there!
  6. Brownyjr36
    Brownyjr36 Bobtail Member
    47
    39
    Jun 26, 2011
    Coon rapids, mn
    I upshift around 1400' and down i try to be below 900. As a rule of thumb, when going down, multiply gear by 5 for mph. Ex. 35 mph, 7th, 25 mph, 5th.
  7. xFreeWord420x
    xFreeWord420x Light Load Member
    243
    78
    Mar 10, 2012
    Leetonia, Ohio
    Wish someone would have told me that when I was going through school.. that is a #### good ROT.
  8. MNoutkast
    MNoutkast Medium Load Member
    441
    151
    Feb 24, 2012
    Elk River, MN
    Someone doesn't have a Detroit, LOL if I shifted at 1400 the truck would fall on its face and laugh at me. That is a pretty good "rough" rule of thumb that can really help newer drivers out!
  9. xFreeWord420x
    243
    78
    Mar 10, 2012
    Leetonia, Ohio
    Yeah, the single stack mack attack would cough and die if I shifted then.. But I think our trucks are geared differently, since every load puts us at at least 80,000.. I shift @ about 2000-2100.. and down at 12-1300..
  10. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    go too u tube , type in the shearch box tons of great info there
  11. MNoutkast
    441
    151
    Feb 24, 2012
    Elk River, MN
    I don't have to run em' quite that high but loaded its probably 1800 or so, maybe 1650 or a little higher empty. But I am either empty at 33,000 or fully loaded to 80,000 there really is no in between for me.
