shifting
Discussion in 'International Forum' started by I9400i, Oct 14, 2011.
  1. I9400i
    I9400i Bobtail Member
    Hi there, I have a little issue with shifting into 1st. I would push the clutch all the way down and sometime would have to jam it into first gear. I would get to the next light maybe 500m later, and it would go into first better than ever.
    Again, this only happens in first gear. Anyone have this kind of issue before? What could it be?
    Thanks.
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    It may just need and adjustment. When was the last time it was adjusted? Either way, the clutch brake isn't working/clutch not fully disengaging when you first try to get into 1st. Making sure the adjustment is right is the first step if not, you are looking at a clutch job soon.
  4. jab8283
    jab8283 Bobtail Member
    38
    16
    Jan 16, 2010
    Indiana, U.S.
    Okay my good man, here is your simple answer. Your clutch is out of adjustment or at the end of it's life. When clutch is properly adjusted, you can easily place transmission in first or reverse and go back and forth between just those two gears. The rest of the gears don't matter in this case. Anytime you cannot easily place transmission into first or reverse gears only, you have a clutch issue. Very easy to fix unless clutch is at end of life then you'll just need a new clutch. Problem solved.
  5. pop-a-top
    pop-a-top Bobtail Member
    45
    11
    Jan 15, 2012
    northeast ark
    if you push your clutch pedal all the way to the floor at high rpm you will tear the spline taps off of your clutch brake and it will never work well untill replaced.
