Shifting
Discussion in 'Questions From New Drivers' started by Cjewell77, Dec 22, 2011.
  1. Cjewell77
    Cjewell77 Light Load Member
    105
    25
    Aug 13, 2011
    shreveport,la
    I am new I am having trouble shifting the new international prostrar. When the green shift light comes on I am scratching gears up and down. This is when I am loaded. Any advice?
    I feel I should be able to do this. Bit is frustrating.
    How long general do newbies have issues shifting?
  3. 7122894003481
    7122894003481 Bobtail Member
    1,996
    Sep 6, 2011
    Green shift light?
    :biggrin_25513:
    Pretty soon all the "driver" is gonna do is turn the key and release the brakes..
  4. Cjewell77
    105
    25
    Aug 13, 2011
    shreveport,la
    No ####. The new international. Has a green shift light. And if u don't shift it will not go one mph faster till u do
  5. rogueunh
    rogueunh Road Train Member
    1,086
    23,110
    Jan 4, 2011
    A shift light? Is this for real?
  6. Cjewell77
    105
    25
    Aug 13, 2011
    shreveport,la
    Yes and the trainer makes you shift with the light not rpms
  7. cruisecontrol
    cruisecontrol Medium Load Member
    340
    115
    Apr 13, 2010
    Rockingham, NC
    you've got to put it in the next gear before the RPM's drop to low. Thats what keeps it from grinding. What RPM does the light come on? I understand you are being trained to shift when the light comes on, however, you can shift at an easily 1300 on level ground...should give plenty of time to double clutch before RPM drops below 1000. Are you double clutching?
  8. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    this is one of the "Maxforce" engines I think?!
    RPM's are low...don't let it get above 1220 for the shift...or below 975.
  9. Stevejun1986
    Stevejun1986 Bobtail Member
    28
    7
    Jan 18, 2011
    San Diego, CA
    ... What company are you training with?
  10. Cjewell77
    105
    25
    Aug 13, 2011
    shreveport,la
    I think I am shifting to slow
  11. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    Just think Lawrence Welk....one and two and....
    Cancel that....you're too young to get that context!!!!!!:biggrin_2559:
    Check with your mother....and try a dancing lesson while you're asking!:biggrin_25525:
