Shifting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by notarps4me, Mar 11, 2007.
Drivers do you
  1. *
    float?
    65 vote(s)
    43.6%
  2. *
    double clutch?
    16 vote(s)
    10.7%
  3. *
    or both?
    65 vote(s)
    43.6%
  4. *
    have an auto tranny?
    6 vote(s)
    4.0%
  1. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    Nope won't hurt it, clutch just stays engaged, and in the tranny all that's happping is one sliding gear is coming out of mesh and another going in. Clutch linkage, and the clutch probably gets more wear when using it every shift than, just floating.
    Nothing can be hurt unless you grind them too much, which is bad whether or not the clutch is used. Just don't rest your foot on the clutch, or slam the clutch to the floor when double clutching.
  3. 25(2)+2
    18,762
    46,051
    Sep 18, 2006
    the road less travelled
    From what I've read, heard, etc about auto-shifts, they are automated float shifting , done by electric or pneumatic actuators, and controlled by computer.
    Full auto- with a torque converter is the only thing that is related to an automotive transmission.
    AJ
  4. NyteWulf
    NyteWulf Bobtail Member
    42
    4
    Feb 23, 2007
    Blacksburg, Va.
    So all you do is shift, no cluth involved at all. Or is there a trick to it? Do schools teach this?
  5. jorlee
    197
    83
    Feb 17, 2007
    ND
    DMV require double clutching for driving Test. Floating is the same principle of double clutching, without the clutch. Which would be useful if your linkage were to break, you would be able to contine normally to a truck shop for repair.
    Upshifting-- Release pressure on transmission by easing off the fuel pedal, while pulling to neutral, then putting into next gear when rpm falls to the right rpm, repeat
    Downshifting-- release pressure on transmission by giving a little rpm, move stick to neutral, raise rpm, put stick into lower gear repeat
    It's the same principal as double clutching.
    upshift clutch pull stick to neutral clutch stick into gear
    downshift clutch neutral raise rpm clutch gear
    Just skipping the entire clutch movement, which breaks torque on the transmission, making it easier to shift. With floating the torque break is down with the go pedal, which is how a Auto shift shifts. I'd assume the ultra shift does it the same way.
  6. MickeyFIN
    MickeyFIN Light Load Member
    212
    6
    Mar 6, 2007
    Turku, Finland
    float up double clutch down even in offroad conditons So was I thought to drive a truck in the army as it´s the fastest way to avoid getting cought under fire.
    Nowadays I have a 18speed Fuller to work with.
  7. Brickman
    Brickman Trucker Forum STAFF
    12,908
    12,210
    Sep 17, 2006
    WY
    Double clutch for driving test might depend on the state. 6 or 7 yrs ago already WY did not require double clutch.
  8. Burky
    Burky Road Train Member
    Mich did not require double clutching when i took the test, and frankly, once the tester saw I knew my way around a transmission, from that point onwards he had no further interest in my specific technique.
  9. slim66
    slim66 Bobtail Member
    30
    Mar 3, 2007
    Eaton Fuller (RoadRanger transmissions) has an interesting video (for newbies, anyway) that somebody on this site once posted a link to. According to Eaton Fuller the advantage to double clutching is that using the clutch 'breaks the torque' on the transmission and reduces the stress on the gears when the transmission is brought into neutral when the gears are floated, and this is when damage is most likely to occur.
    I would think if one is proficient at floating and can do it consistently without clacking or grinding the gears that it wouldn't hurt the tranny but that's a big if.
  10. MickeyFIN
    212
    6
    Mar 6, 2007
    Turku, Finland
    Actually it takes the Stress of the Forks that moves the gears while you use the clutch...
    I sometimes dip the clutch a little just when I feel the stick doesn´t come out softly.
  11. Brickman
    12,908
    12,210
    Sep 17, 2006
    WY
    That torque release also comes from lifting your foot from the throttle before sliding the trans out of gear.
