Shock tower damage - how did this happen?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Aug 25, 2015.
  1. rollin coal
    rollin coal Road Train Member
    13,620
    27,999
    Mar 29, 2008
    TN
    I noticed the left front shock on my drives was sloppy up at the top where it's mounted. So I took it off and the holes in the mounting bracket are wallowed out like somebody counterbored them. The shock actually did that to it. The one on the other side was not sloppy but just to have a look see I took it off and it was starting to wallow out the same way. The brackets on the top at the back axle are not like this. This is an AG380 suspension. I have no unusual wear on my tires. The only thing I can figure is maybe it was because I re-used the original self locking nuts and bolts when I put shocks on it several years ago? I dunno??? Weird.
  3. rollin coal
    13,620
    27,999
    Mar 29, 2008
    TN
  4. AModelCat
    164,674
    The only thing I can think of is that the bolt felt tight when it was installed but not tight enough to press the bracket together tight enough to prevent the steel collar inside the shock bushing from turning and wearing the bracket.
    OLDSKOOLERnWV and rollin coal Thank this.
  5. rollin coal
    13,620
    27,999
    Mar 29, 2008
    TN
    Now that you mention that it was a booger to get off there with a half inch impact and none of the others were like that. I didn't look too close at the threads I bet they are messed up. Seems like I used a 3/4 impact years ago and tightened them up really good. But I guess maybe not.
  6. Cat sdp
    Cat sdp . .
    21,304
    76,205
    Apr 8, 2012
    Orion's Belt
    Probably from sitting to much. :)
    I had to put a washer behind my top rear shocks .... Because they were a little loose and I couldn't get them tight ...But I have primaax.....
    New parts towers/bolts/shocks will cure it.
    rollin coal and mp4694330 Thank this.
  7. rollin coal
    13,620
    27,999
    Mar 29, 2008
    TN
    Yeah sitting in the driveway like that for weeks on end is actually harder on equipment than driving it don't you know?.? :)
    truckon and mp4694330 Thank this.
  8. FLATBED
    FLATBED Road Train Member
    Pretty sure KW had issued a service bulletin in regards to that problem back when AG 380 was getting popular
    rollin coal Thanks this.
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    My 05 had the AG380, the upper shock brackets were not near that thick.
  10. rollin coal
    13,620
    27,999
    Mar 29, 2008
    TN
    These are aluminum and I'm wondering if the new ones are too.
  11. Oscar the KW
    12,247
    28,120
    May 19, 2011
