shocks o7 vnl
Discussion in 'Volvo Forum' started by damil, Nov 1, 2015.
  1. damil
    damil Light Load Member
    171
    248
    Sep 23, 2012
    I blow a drive shock or two every 6 months or so it is worse during harvest due to the slightly overweight hauling I do. My question is there are two holes on the top shock mount. my front drive shocks are extended to the top hole while the rear drive is compressed some to the bottom hole. is this a normal set up and if so why is it like that. I have replaced the shocks before and just replaced them like I took them off. What would the reaction be if i placed them all in the same holes. would I gain or loose anything....Thanks in advance
    mp4694330 Thanks this.
  3. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    It depends on the length of travel for the shocks. If the ones using the top hole are almost at their max limit then they will either break or pull the shock mounts off. I have seen both. You can remove shock from top mount. Over extend air suspension and extend shock to max length and see where the hole lines up compared to the bracket. If it is short use lower hole if you still have travel left in shock then you can choose whichever you want. You don't want the shock to be the limiting factor in your suspension.
    mp4694330 and damil Thank this.
