1. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    It's my first semi truck so sorry if this is already common knowledge and hopefully its the correct sub for these questions.
    I have a plug on the side of the truck. Truck came with xantrex freedom hf 1000 inverter/charger that I understand is stock from the factory.
    If I run a generator to that plug will that charge the batteries and provide power to the outlet sockets?
    If I upgrade the inverter and get a 3000 watt generator would I be able to plug in an 8,000 btu portable air conditioner? Is that how this would work?
    What are good brands for a 3000 watt inverter/charger?
    truckdriver31 Thanks this.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    mite be a block heater plug
  4. Malt Ball Cult
    Malt Ball Cult Light Load Member
    151
    443
    Jul 24, 2021
    If it's a shore power plug, there may be a separate duplex outlet that's isolated from the inverter circuit. That's how my last 2021 Cascadia was set up.
  5. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    Closest thing I can find online shows block heater by the engine bay and separate shore power inlet on cab.
  6. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    So just plug it in and just see which sockets work with inverter off?
  7. Malt Ball Cult
    151
    443
    Jul 24, 2021
    That's what I'd do. You could check without plugging it in, see if you have an outlet without inverter power, that's probably the shore power outlet.
  8. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    that white plug is a 30amp plug
  9. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    should be an owners manual with the truck......
