Short WB Day cab weights
Discussion in 'Experienced Truckers' Advice' started by Big Road Skateboard, Oct 22, 2025.
  1. Big Road Skateboard
    7,096
    40,268
    May 2, 2021
    Hey guys, working up some #'s for a customer, and the job would require a day cab So, what would work for me would be short wheelbase in the 379, W9, FLD, T6, 9400, etc class of truck. Not like local LTL trucks.
    Anybody got real #'s on what these trucks scale at?
    Thanks
    Sons Hero and Oxbow Thank this.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    We have quite a few in the yard,I'll take a look tomorrow,couple Peterbilts,a bunch of freightliners that are really short wb.
    Oxbow and Big Road Skateboard Thank this.
  4. Cdemars316
    Cdemars316 Road Train Member
    1,028
    6,631
    Nov 10, 2018
    My truck was a daycab from factory... Well cab and chassis and has a 245" wheelbase so not short and a c15 and is listed as factory weight of 16500 would think a true daycab short wheelbase is going to come in under 15 with the right engine in it
    MACK E-6 and Big Road Skateboard Thank this.
  5. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    I have a 1974 w9 with an 855 Cummins and 44 k rears on extended leaf walking beam with a wet kit and spoke wheels…it weighs around 16500…
    A long time ago I drove a 9370 with 855 Cummins and most everything aluminum including the frame it weighed approximately 14000
    Both of these were around 180 inch wb
    My l9000 weighs 18900 with 3406 46k rears 20 k dual steer front and a 1/2 inch thick frame it’s got 8 aluminum wheels on the back and a wet kit it’s pretty long for a daycab at 252
  6. Oxbow
    Oxbow Road Train Member
    13,649
    141,475
    Nov 24, 2015
    My 89 379, 244 wb, all aluminum wheels, is about 18k. It has a 3406 with a retarder, and 18 speed, 300 gallon fuel tanks. I should think you could find one less 16k.
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,401
    7,942
    Jul 11, 2012
    in the bush somewhere
    You didn't mention Western Star, but for what it's worth to you, I run a 2020 WS 4900ex day cab. 6nz Cat, 18 speed, 220" wheelbase. With the pneumatic blower on and full of fuel I'm at 17740....
    We have a couple Freightliner Classics as well, spec'd similarly and they're I think around 16500 or so.
  8. SmallPackage
    5,778
    18,552
    Dec 20, 2019
    Marion Texas
    Last single drive, short, day cab I know of personally was bought in ‘03. An FL. It weighed in at 12,890 without fifth wheel. We buy without fifthwheel to avoid the extra FET on them and then add our own.
    I’d figure the 16,000 range would be a start on tandem drive. My ‘67 351 weighs 16,600.
    Big Road Skateboard and Oxbow Thank this.
  9. Big Road Skateboard
    7,096
    40,268
    May 2, 2021
    Thanks for the #'s everybody. Much appreciated
    Oxbow Thanks this.
  10. SmallPackage
    5,778
    18,552
    Dec 20, 2019
    Marion Texas
    Aluminum frames saved close to 3000 lbs. Then there were rare Rockwell aluminum drive axle housings and gear carriers, aluminum steer axle beams that shaved off a bunch. Spicer had aluminum boxes back then. Wasn’t uncommon for an all aluminum west coast truck to weigh 10,000.
    W923, Big Road Skateboard and Oxbow Thank this.
  11. Ruthless
    Ruthless Road Train Member
    9,176
    91,111
    Aug 28, 2010
    The City.
    I’ve seen tandem axle tractors advertised in the fifteens, that said, I guess it’s a bit more of a question of what type of terrain are you going to be operating in and how much power do you really need? You can get one of those ######### medium duty trucks built as a tandem with a 9 L motor and a 10 speed, you probably be 11,000 pounds give or take with something like that. I don’t think I really want to be taking something like that out through any hills though for hauling any real weight, or going any real kind of distance.
    A Man told me a long time ago, if you wanna actually haul real weight, don’t worry about what you weigh empty just build it so that it ain’t gonna break when you load it
    Ymmv
    MACK E-6, wis bang, Numb and 2 others Thank this.
