Should I go through the Loaded or Empty scale lane?
Discussion in 'Questions From New Drivers' started by CosmoK12, Jul 16, 2020.
  1. CosmoK12
    CosmoK12 Light Load Member
    130
    154
    May 26, 2020
    I’m on a 7 drop load, final drop is a whopping 3 boxes (3X3X3 ft in size ) with a total weight of 230 pounds.
    I’m in a reefer and will be crossing the Cordelia CA scale heading west bound.
    empty lane moves faster, will CHP know I have 3 boxes in the trailer? Certainly not by weight.
    Upinsmoke and D.Tibbitt Thank this.
  3. D.Tibbitt
    157,290
    Do what u gotta do. If it really saves that much time.. Like what , 13 seconds ?
  4. CosmoK12
    130
    154
    May 26, 2020
    A few minutes, mornings are usually busy through there
  5. D.Tibbitt
    157,290
    I wouldnt worry about it . Hit the mt lane and be gone.
    CosmoK12, farmerjohn64 and Upinsmoke Thank this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    If a few minutes matter, you are in the wrong industry.
    Relax, go through the lane you know you need to and stop speeding through truck stops. After all it's usually the people that have the "minutes matter" issues that do.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    If your reefer is turned on, you'll probably want to use the loaded lane. If your 3 boxes aren't a cold load, use the empty lane. Of course if they decide to pull you in for inspection and see that you are still under a load regardless of size, you'll have a problem.
    alds, okiedokie, Upinsmoke and 2 others Thank this.
  8. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    I think you will be fine. Just remember, if DOT wanted to be jerks, like they sometimes are they could give you a citation for failure to obey a traffic control device, if they decided to bring you in for some reason in the empty lane.
    That may sound trivial, but here is an example of a DOT jerk. A friend of mine was in the middle of a leven 1 inspection. AFTER the breaks on the axle were inspected, the pancake in one of the maxi break chambers failed and started leaking air. He had a spare break chamber with him, and started to replace it, and they still put him out of service....
  9. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    Ohio got Me once, for a low tire, 50 lbs. I had obviously just picked up a piece of metal, before pulling in, it was leaking pretty good. OOS, air it up, you can go.
    D.Tibbitt and Upinsmoke Thank this.
  10. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    I always say why risk it.. whaddya gain
  11. Long FLD
    Long FLD Road Train Member
    12,958
    54,388
    Mar 4, 2015
    Do they have chase cars there? They didn’t used to. We would just move over a lane or two and drive right by when we were bringing calves off the coast. Truckee was the only one I’d ever cross, you can’t really breeze by that one when you’re slowing down for the ag check.
    Rideandrepair, D.Tibbitt and 650cat425 Thank this.
  12. bad-luck
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    Isn't that ridiculous? Some of these guys really can't think outside of the Box. There's no Gray area with them
    Rideandrepair and D.Tibbitt Thank this.
