Should you Pressure wash engine compartment of a semi truck?
Discussion in 'Ask An Owner Operator' started by Ikamob01, Dec 22, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Should I Pressure wash engine compartment of a semi truck?
  3. Cdemars316
    Cdemars316 Road Train Member
    1,177
    8,163
    Nov 10, 2018
    I do, usually at least twice a month, just stay away from the wiring harnesses coming out of the firewall and the
    computer on the engine. The reason I do is to see any new leaks or seepage that is happening. Also I pressure was
    everything, complete underneath, that way when you get inspected it makes it easier on them, and you.
  4. ultra truck
    ultra truck Bobtail Member
    17
    7
    Oct 21, 2020
    Deland Fl.
  5. ultra truck
    17
    7
    Oct 21, 2020
    Deland Fl.
    It's ok to wash it but that depends on what truck orore how old it is. Don't was alt, starter,any moduls.or computers or wire connectors. You can bag up some things while you wash it but don't get electric components wet.
  6. bad-luck
    bad-luck Road Train Member
    3,517
    6,519
    Nov 16, 2013
    Baltimore, Maryland
    Yes, I have done it all the time at the Blue Beacon.
    flood, bryan21384 and ducnut Thank this.
  7. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    I pressure wash engine bay all the time before I drop it off for oil change. I don’t want to spray off new lube.
    Siinman Thanks this.
  8. Ikamob01
    314
    195
    Dec 4, 2021
    Ok. That make sense.
  9. ducnut
    ducnut Road Train Member
    2,683
    8,145
    Dec 31, 2010
    SPI
    The nice thing about Blue Beacon is they use whatever soaps they have, which will dissolve about anything, without having to get very aggressive with high pressure water. If you have them do it semi-regularly/monthly, the engine stays nice and clean.
    bryan21384 and Siinman Thank this.
  10. TylerVS
    TylerVS Light Load Member
    102
    170
    Nov 11, 2012
    Sully, IA
    I just turn the heat up and pressure way down around the engine. I'd had it a few years ago a couple times where my truck went into limp mode after pulling out of blue beacon. Some water must have gotten into a connection that had to do with the throttle position sensor (that was the code I got anyway). Once it dried out it was fine, but I just quit having them wash under the hood. I'm pretty careful about putting a lot of pressure in around the engine now when I wash it myself.
    Siinman and Arctic_fox Thank this.
  11. Arctic_fox
    4,772
    27,293
    Sep 16, 2016
    Yup same. When i get a chance i take it to a manual truck wash and typically cover anything with wires or sensors and only really power wash around common areas for drips and seeps. Only time i really hard wash the engine is if i see a lot of buildup someplace to see if its a leak or something.
    That said back when i first started driving may had me take my new truck to a beacon since the last driver left the truck a mess. They had a new guy there spray the air intake. And sure enough i got about 100 feet before it hydrolocked.
    TylerVS Thanks this.
