Side box cable
Discussion in 'International Forum' started by Steve.b, May 3, 2018.
  1. Steve.b
    Steve.b Bobtail Member
    4
    Does anyone know how to open the side box on a 9400i to replace the cable?
  3. kwswan
    kwswan Road Train Member
    2,048
    11,271
    Jul 26, 2009
    mcminnville,tn.
    Raise the mattress,drill a hole above the latch then use a jigsaw to cut a hole big enough to get your hand in to open the latch.I have had to do this on 2 of them.
    Steve.b and windsmith Thank this.
  4. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    IIRC, the cable also has a clamp behind the side wall covering that holds the sheath, preventing you from pulling it through and fishing the replacement down. So you'll need to remove the interior trim and side wall to get the replacement done. If you remove the side wall, you might be able to get it open by pulling on the cable sheath on the far side of that clamp without having to drill / cut a hole to get your hand in to the latch.
    Steve.b Thanks this.
