Signature Series 600 Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Skinner Aldean, Nov 11, 2024.
  1. Skinner Aldean
    Skinner Aldean Bobtail Member
    20
    59
    Feb 21, 2021
    I have a 2002 Peterbilt with a Signature Series 600 Cummins in it. It has an 18 speed, 46k rears, 3.90 gears in it if that matters or not at this point. About 3 years ago or so the engine developed a low fuel pressure issue. The amber check engine light will come on at high speeds above 55mph. When the light comes on you can feel a drop in power from the engine. In cold weather around the 30-40 degree range the engine does perfectly fine until later in the day for whatever reason when the fuel tanks are low and then the light comes on and power loss. In the summer it takes little time for issue to begin right off the bat.
    I have had it in and out of shops and watched mechanics pull out their hair on the issue. I have had new fuel lines from the tanks to the fuel filter replaced. New injectors, new fuel pump and everything in between that we can think of. I'm hoping someone here has had the same issue and hopefully can point me in the direction of resolving this issue. Love my truck and I want it running at full power like anyone else would.
    Thanks for any help.
    Oxbow Thanks this.
  3. Sons Hero
    Sons Hero Road Train Member
    3,337
    34,758
    Jan 8, 2021
    Indiana
    @OLDSKOOLERnWV might be able to help you. Think he’s got a Big Cam. A Signature 600 is a version of an N14, am I correct?
    Skinner Aldean and Oxbow Thank this.
  4. Oxbow
    Oxbow Road Train Member
    13,775
    143,020
    Nov 24, 2015
    Dangit, CRS strikes again..........I swear there was another thread dealing with this same exact problem recently, although I don't remember what engine. Anyone else remember?
    To the OP, it's not making oil is it? Probably not as many folks have looked at it. I'd probably grab an oil sample just to be sure.
    Skinner Aldean and Diesel Dave Thank this.
  5. Oxbow
    13,775
    143,020
    Nov 24, 2015
    062 Road Train Member
    6,354
    34,057
    Oct 20, 2013
    Checked tank vents?
    Does it have a fuel temp sensor?
  7. ElmerFudpucker
    7,220
    79,032
    May 17, 2024
    No an sig 600 is a pre emission isx.
    In the summer does it do it regardless of fuel tank level? Or is it always when the fuel tanks get low?
  8. Big Road Skateboard
    7,298
    41,609
    May 2, 2021
    Not me (that i remember anyways) and I can't remember the thread.
    @Diesel Dave maybe, @Goodysnap? I can't remember who the ISX guys are here
    OP, what is the fault code, what is the fuel pressure, and have you verified fuel pressure when this problem occurrs?
    Skinner Aldean, Diesel Dave and Oxbow Thank this.
  9. Diesel Dave
    9,806
    34,002
    Jan 20, 2010
    Hesperia, Ca.
    He has a signature 600, it’s a pre emissions engine, I have a 2016 ISX 15. He having the similar issues that the electronic CAT’s (3406)had once the engine start working hard. And I can’t remember how they resolved it. It’s in here somewhere. I do remember them running a clear see through fuel line that they could see if the fuel system was getting air in the system cause that’s probably what the OP is getting.
  10. Skinner Aldean
    20
    59
    Feb 21, 2021
    In the summer within say 30 minutes of running with full tanks it starts in.
    ElmerFudpucker and Oxbow Thank this.
  11. Skinner Aldean
    20
    59
    Feb 21, 2021
    The code is PID-94, sorry I didn't post that before it slipped my mind.
    Oxbow Thanks this.
