Silicosis?
Discussion in 'Oilfield Trucking Forum' started by CamryXSE, May 20, 2023.
  1. CamryXSE
    CamryXSE Light Load Member
    100
    45
    Sep 10, 2020
    Thinking about the oilfield again. Haven't been out since 2014.
    Last time I was out we were blowing sand into the thingys (9 years ago). We worked in clouds of dust though usually with a respirator. Then I heard they changed the way of doing that.
    I tried hauling crude in ND but couldn't stand the thought of breathing those gushing carcinogens while working the tanks.
    So I'm just wondering, is silicosis still a thing? Fault me for my reasoning but I think if I can make a good living without risking my long term health, I should do that.
    Forrest Griffin and Stephan Bonner gave everyone a great show if you like blood. I'm sure no shortage of women and plenty of cash. Smart move if you don't mind living off painkillers and dying in your mid 40s. Do you get my logic?
    TIA
    Chinatown Thanks this.
  3. RockinChair
    RockinChair Road Train Member
    5,401
    14,543
    Feb 19, 2012
    Lubbock, TX & thereabouts
    The EPA made some kind of regulatory change to address respiratory exposure of silica sand a few years ago which resulted in a shift from pneumatics to sandboxes.
    As far as crude vapors go, you could wear a respirator if you're concerned about vapors. I guess leases up in ND don't use vapor recovery and tank climbing still a thing there?
    snowman1980, JoeyJunk and CamryXSE Thank this.
  4. CamryXSE
    100
    45
    Sep 10, 2020
    Yeah, I heard about those sandboxes. I'm glad about that.
    You know, In 2014 they were climbing up the crude tanks, venting them and working them. Now, I don't know.
    One trainer told me if I wore a respirator I'd be the only one and it would slow me down and just wouldn't work out. I tried two different companies but never got out of training.
  5. RockinChair
    5,401
    14,543
    Feb 19, 2012
    You'll change your mind when you start driving around them.
    You have to wear a respirator at leases with high H2S, so I don't see why it would be a problem for you to wear one at the other leases too.
    What happened?
  6. CamryXSE
    100
    45
    Sep 10, 2020
    They just weren't used to someone so wary of the fumes. They thought I couldn't do it. They may have been correct. The fumes come gushing out of the tank. I'm not just trying to do it without passing out, I don't want that stuff accumulating in my blood and I don't want it giving me a bad doctor's report even 20 years down the road.
  7. 201
    201 Road Train Member
    12,808
    26,366
    Apr 16, 2014
    high plains colorado
    Don't be sili,,,cosis. Not sure if "blowing sand" is a big risk, I hauled silica sand to foundries, and workers that inhaled that fine mist of sand, were largely at risk. Same with crude oil, I think. Fumes aren't the same as up to your waist in it. Far as something in your blood 20 years from now, Burger King Whoppers are probably just as bad. There is a greater awareness to hazards on the job today, unlike years ago, when I was told to "just turn your head and hold your breath".
    W923, CamryXSE and jcatel Thank this.
  8. RockinChair
    5,401
    14,543
    Feb 19, 2012
    Did they not teach you to stand on the upwind side of the hatch before you open it?
    Also, if you're going to a lease that has a lot of vapor pressure in the tanks, go to the farthest tank downwind and open its hatch so that the entire tank battery will depressurize before you open the hatch on the tank you're supposed to work.
    Nowadays, more and more operators are starting to use LACT units which means you don't have to work a tank. And many of them also have vapor recovery, but for the ones that don't you can always hook up a hose to your vapor vent and run it out away from the trailer to keep the vapors away from your breathing zone - and the truck's intake.
  9. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    They still blow sand, just way way less than before. Up here silica dust has been taken seriously since 2012.
    I have noticed the big pneumatic company locally that had a bunch of hoods has a field full of trucks and cans. Not sure whats going on there. Their website says they are still hiring.
    There is also a silo rental company that appears to not have many out on pads. Sandbox and hopper bottom are the main ones here in PA, OH and WV.
    Nextier still runs cans. Have their own drivers in the T800’s they got from Trican. They have owner ops as well.
  10. RockinChair
    5,401
    14,543
    Feb 19, 2012
    How do they unload a hopper bottom, slide a transloader under it?
    W923 and Oxbow Thank this.
  11. 201
    12,808
    26,366
    Apr 16, 2014
    I loaded off rail cars, and it's a bucket elevator. Makes a mess, if I remember.
