Silver hub oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cabwrecker, Oct 1, 2017.
  1. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,425
    Mar 23, 2012
    Just got a hub seal job done on my 630. The job is warrantied through the shop it was done at.
    Kept the old bearings (conmet) and replaced the spindle cone. Shop installed all seals, reinstalled all bearings and set preload step by step according to manufacturer specs and followed all manufacturer torque specs.
    Oil level is stable.
    The oil is turning/has turned silver. This is after roughly 5kish miles and it's slowly been turning this fresh Lucas hub oil metallic.
    My initial thoughts are the new cone working in, wanted to run it past you guys and get your thoughts?
    Like I mentioned, oil level is stable. Hub temp is normal. No actual metal shavings in the oil, just like pigment quality mettalic look to the oil.
    What do you guys think?
  3. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    Why not take it back to the shop that did the work?
    SAR, rabbiporkchop and Snailexpress Thank this.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    IMMEDIATELY. Wheel off or hub fire isn't pleasure.
    rabbiporkchop and JimmyWells Thank this.
  5. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    bearing don't "wear in" by shedding metal.
    i have seen some assembly lubes that look like micro metal specs when they mix in with oil. i think its the moly in them that does it.
    i'd get it figured out fast.
  6. AModelCat
    164,678
    Doesn't sound good. I'd get the shop that did it to check it out.
    rabbiporkchop Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Why was the LMS cone replaced? Were the bearing cups replaced to match? The cone spacers are matched to the hub for proper bearing preload upon assembly. Are we certain that the spacer cone was the same as the old? I would only recommend replacing the Hub and cone as a set. Most commonly seen would be that the cups were not fully seated in the hub upon replacement. Especially on aluminum hubs can be a bugger to get them seated. The other is that a typical bearing back-off adjustment was performed. LMS hubs are always torque tight- no back-off. Either way a teardown and inspection is in order.
    Broke Down 69, rabbiporkchop and mhyn Thank this.
  8. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Wheel bearings do not wear in. Silver is a sign of metal in the oil and something breaking down. Take it in right away.
    SAR and rabbiporkchop Thank this.
  9. Rackpass 85
    Rackpass 85 Light Load Member
    294
    214
    Jun 12, 2017
    Get to shop asap!
  10. Schnot
    Schnot Bobtail Member
    26
    9
    Jul 8, 2011
    Ringtown, PA
    Yep thats certainly metal in the oil as others have said. I just did mine in a 91 FLA and the drivers side was silvery like you explained yours to be. Once I got it apart and cleaned the bearings, the "coating" was coming off of the bearings. It was almost like the chrome plating was coming off.
    Now I know that bearings arent chrome plated, thats just the easiest way that I can explain what it was doing.
    Heavyd Thanks this.
  11. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Yep, like a bad heat treatment or something and that outer layer of hardened steel just sheds off.
