silver super mini 8 HELP :(
Discussion in 'CB Radio Forum' started by Jolsen, Apr 5, 2010.
  1. Jolsen
    Jolsen Heavy Load Member
    951
    272
    Mar 6, 2010
    East of the big crick
    ok so i took you guy advise and bought a super mini 8 single cable. i am now running one antenna the 2 foot one that cam with the truck. still wont see home till the end of the month to get my astatic liner loaded white 1k antennas and astatic noise canceling mic.
    anyways my problem is i can hear people now and been yelling braker 1-9 can i get a radio check, any of you drivers have a copy of this radio? for 2 days now at every truck i have seen. and not one response. i used to get a few here in thier when i was running the duel non matching antennas off the duel non factory coax that the previous driver left in the truck. but now i get nothing. any ideas or sujections would be helpfull. i bought the silver super mini 8 coax rather then the copper cause i couldnt read a diffrance betwwen that and the K40 expensive stuff.
  3. Jolsen
    951
    272
    Mar 6, 2010
    I changed the elbow out from the 1.5foot antenna and put it on the 2 footer and i got a answer in the 15 miles between the shipper and the pilot im bout to lay down at for 10. is it possible for a 90* joint to go bad?
  4. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    Before you go any further, can you provide some facts on your current setup? Using a stand alone meter not the one that is in the radio, can you tell us your SWR reading? This is really important to know.
    Please stop using your CB radio until you know that the SWR reading is less than 3.0 or else you can and will damage the power transistors (some call them "the finals") and turn your CB into something that can only transmit a 1/4 mile if that. A SWR reading of 3.0 or higher indicates a connection problem like a break in the coax, faulty antenna or bad antenna ground.
    Once your SWR is less than 3.0, Is it possible for you to borrow a 4 foot or longer antenna from someone to use for a test. Those 2 and 3 foot long antennas are not exactly known for their ability to get signal out.
  5. Jolsen
    951
    272
    Mar 6, 2010
    im currently running a cobra 19 no clue what my swr readings are. i am tossing it in the sidebox soon anyways. i have a cobra 25 from the early 80s heading my was via my uncle whom used to be o/o back in the 70s and 80s. when i get that and my astatic liner loaded 1k white antenna and astatic 636l mic i plan on going to a shop to get them to tune my antenna to the cobra 25. im not letting just anyone open that box. i want to go to sparky or someone simmiler that really knows thier stuff to get the radio peaked and tuned. barrow an antenna? i drive otr so does my whole family problem is they dont care about keying up and hardly turn thiers on anymore let alone are never in the same state at the same time all ways 2 days off lol. im in Tx 2 days later dad calls im in tx lets go eat. umm im in TN missed me again. o well maybe next time.
